E46 (1999 - 2006)
Old 02-05-2013, 08:12 PM
01e46sprt 01e46sprt is offline
Mein Auto: 2001 Bmw 325ci sport
That does kinda sound like a pulley. But the after noise when shut off I have no clue about ?
If I was you and could afford a good Indy shop with a good reputation I Would take it over
And have them diagnose everything. Most of them only charge an hr labor for diagnosing.
And if it's affordable let them repair it...if not take the report he gives you to a cheaper shop
And let them do the repair.
Old 02-05-2013, 09:33 PM
Jsmk23 Jsmk23 is offline
Mein Auto: 02 BMW 325i
Yeah imma call tomorrow to local shops and see how much they charge for a diagnostic test.
Old 03-22-2013, 11:51 PM
Bad news today fellow fanatics.
Driving up the interstate with my normal every 2 weekends drive from San Diego to Palm Springs, within 30 mins on the freeway, I noticed my battery light came on my dash.
First time I ever seen this.
After 5-10 mins from when I started driving I noticed my temperate needle went up fast.
I pulled over when it went up, and when I went to lift up the hood there was no smoke.
So I went back in the car to start it up and I noticed my steering wheel was tough to turn. So I figured it was my power steering pump.
When I checked under the car it was dripping slowly.
So I just called my roadside assistance to tow it back to a shop.
So I was wondering if you guys could give me a heads up on what it could be more or less besides that the shop could charge me a fortune.
Thanks.
Old 03-23-2013, 12:05 AM
lgr122 lgr122 is offline
Mein Auto: '04 e46 Touring M-Sport
Belt snapped? Water pump +Alternator +Powersteering pump are all used by that same belt, aren't they?
Ofcourse can be that something else broke with it, so should check carefully everything which is nearby.
Old 03-23-2013, 02:04 AM
PerfectStorm01 PerfectStorm01 is offline
Mein Auto: 2001 320Ci
Yes, they are. Noise was probably a pulley to begin with. If it is, great time to replace the tensioner pulley, idler, cooling system refresh, new belts, etc. Take a look at your water pump and power steering pulleys to make sure they are not cracked and badly chipped from this incident.
Old 03-23-2013, 09:26 AM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
All poster having these noises that go away after 5 mins or so, and are more prevalent when cold should def. check all pulleys, water pump ect. You do have to remove the belt(s) to do it, but if one fails it could really cost you big time to fix it. The thrown belt can severely damage other items. Do not take this lightly.
Old 03-23-2013, 11:38 AM
Yeah I figured. I'm not taking this lightly. First time I had this happen to me.
