Old 02-02-2013, 02:12 PM
Nitrogen's Avatar
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
Disassembled Vacuum pump pics for FYI
Here are a few pics of when I took apart my vacuum pump to replace and seal the gaskets.
Might help someone who wants to pull there's off and also shows what the gusts look like for those who are interested. Didn't know if I should post here or in the DIY section since it's only a pictorial. Veterans of the forum let me know if this should have gone DIY or here for future reference. Thanks!!!
Sent Via iPhone using BimmerApp
Old 02-02-2013, 03:13 PM
tampamark tampamark is offline
Mein Auto: 650 Sold - '12 Jaguar XK
Very nice, I need to get mine out of the way soon. I have not had much time of late but I bought the seals, just need to get it going.
Perhaps if you get a bit more details about the process it would be good to move into the DIY section. If you don't mind, I have a couple of questions:
  1. What did you have to remove or disassemble to get to it? I believe you only have to loosen up the other hoses to move them out of the way, but in a DIY for a 5 series they mentioned pulling the fan and shroud.
  2. From what I have read you have to turn engine crank over to get the slot to line straight up with a 27mm or 28mm socket (can't remember offhand which size), did you do that?
Old 02-02-2013, 03:53 PM
Nitrogen's Avatar
Hi Tampa. as you can see I didn't remove anything. The only thing that will come off is a bracket that is attached to the pump screws. It's really easy to do. I didn't turn the engine by sheer luck the slot was straight up and down (kind of) like it should be. If it wasn't it would have taken forever to get that thing on. The shaft that needs to go into the slot is much like a fish tail and just flops from side to side. So if you try it with the slot on the side it will be very hard, it would take more time to insert it than to do the whole repair job. After you remove it you can see where your slot is and rotate the crank not very hard to do as I did it to replace my AC belt. Let me know if you need anything else. Oh I also put a coat of silicon around the outer edge to help create a better sell I also put some on the O ring to hold it in place. Don't forget to remove your rubber cover on the little access nipple on the front cover before you start that thing falls off all the time, set it aside till your done. I just zip tied mine so it doesn't get knocked off. Hope that helps.
Old 02-02-2013, 07:09 PM
Thanks, that is all good to know!
If I do have to rotate the crank, where do you connect up the socket, is it in the middle of the drive pulley at the bottom of the engine?
Old 02-02-2013, 07:16 PM
Nitrogen's Avatar
That's right it's in the center of the crank pulley. Just remember to use a long ratchet or at least a cheater bar it will be much easier.
Old 02-03-2013, 06:41 PM
Thanks Nitro!
Old 02-04-2013, 11:23 AM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
Thank you!
Once a 6'er, always a 6'er.
Old 02-25-2013, 08:43 AM
I performed this DIY over the weekend, not that bad. Thanks to Nitro for the pic's, also I found a very nice DIY created by an owner of a 745. So it is very similar. Also, I went ahead and bought the oil pressure sensor and replaced at the same time. It is right underneath the pump and easy to get to when the pump is out.
http://www.bimmerfest.com/forums/sho...d.php?t=645452
Another DIY from an E46 owner:
http://www.bimmerforums.co.uk/forum/...repair-t89903/
BMW calls it the Oil Pressure Switch, part # 12617620512 from www.getbmwparts.com. cost was $19.96 with shipping and handling fee.
There is plenty of documentation on the web about replacing the switch and pump along with the seals needed, but nowhere did I find a comprehensive list of tools required. So I will post those now so it is documented. I gave myself plenty of time for tool runs, plus I have a Harbor Freight (torx sockets) and Sears (24mm and 27mm deep well sockets) 8 minutes away.
Here is what is required for Vacuum Pump:
Removing Acoustic cover - 10mm socket
Upper filter and intake tube - flat head screwdriver to loosen clamp
Power Steering/Dynamic Drive fluid line - 10mm socket
Vacuum Pump mounting bolts to engine - E8 (female torx) socket
Vacuum Pump disassembly - T25 Torx bit male
Vacuum Pump alignment at bottom crank (if the receiving slot in engine is not straight up) - 27mm deep well (I used a deep well, regular would work also).
For the Pressure Switch:
24mm deep well socket
In the other threads you will find info regarding BMP Designs who makes the replacement gaskets:
http://www.bmpdesign.com/product-exe...arch_model/154
Old 02-25-2013, 07:29 PM
Nitrogen's Avatar
Nice work Tampa glad my photo's helped wish I would have done a proper guide.
Maybe next time.
Cheers
Old 03-11-2013, 11:05 AM
Skarv Skarv is offline
Mein Auto: '05 645i convert
A few details that might help...
Thanks Nitro and Tampamark.
Your pix & made this very easy to do. From my experience, I'll add a few minor details that might help the hesitant.
First, the torx 8 female socket is critical. I have often used plain sockets on male tox nuts, but in this case, if you strip the head, you will really lament.
My tips.
1) The hoses in front of the pump on the bracket seem stiff... but they do move far enough out of the way once the nuts are released. These two 10mm nuts are the first thing that should come off.
2) The third torx bolt is underneath and toward the left as you face the engine. This one is really the key reason a proper socket is needed. Its hard to reach, but you will find it.
3) Extra explanation of the need to turn the engine: The pump has a square metal tongue that fits into a slot in the shaft that is exposed in end of the head. The tongue in question can flop maybe 15 degrees in either direction so if this tongue is not vertical, when you install the pump, the tongue will flop down, and not align with the slot in the shaft (cam shaft i would guess) that drives it. If vertical however, lining things up is easy since the tongue stays put. Also, you don't need a socket and cheater bar to turn the engine. All I did was grip the serpentine belt and pull it while pushing balancer around firmly. She turned pretty easily until the slot was vertical. Do same to the pump and slide her in.
4) Hose clamp... I found that the permanent hose clamp needed tightening as the hose had dried out a bit. Easy. When hose is put back on, just take a pair of diagonal cutters and press the horseshoe tighter.
No more leak.
Thanks for doing the pictures. That's the hardest part with greasy oily hands!
Old 03-11-2013, 03:26 PM
Originally Posted by Skarv View Post
3) All I did was grip the serpentine belt and the balancer and push firmly and steadily. She turned pretty easily until the slot was vertical. Do same to the pump and slide her in.
That is genius in it's simplicity!!! That would have saved me $10. No worries, maybe I will have a use for a 27mm down the road, still saved a bunch over having it done at a shop. But that is a great tip
Someone else in another thread likened the Vacuum Pump piece to a fish-tail flopping around. That is very accurate! Even in the vertical the pump is such a tight fit into the engine that I couldn't maintain it in a perfect vertical orientation and had to wiggle it a bit to get it to marry up properly. Would have been impossible in a non-vertical orientation on the engine side.
Old 03-11-2013, 06:21 PM
Thanks Tampamark. Necessity is the mother of invention. No sockets that large at the local hardware store.
One more rumination on this fix. I saw in some of the fixes on the net that some people were putting red permatex formagasket sealer on the o rings. Clearly the pump was designed for the o rings only. The reason I added sealer (sparingly) is twofold: The pump mounts to the head, and these tend to get quite hot. O rings in my experience lose their elasticity with this kind of heat. Two: The vacuum pump is "vacuum" for half of the stroke, but once past the vacuum port, it actually becomes a pressure pump for the second 'stroke' assuming you used some of the vacuum on your brakes or whatever. I believe that it is the pressure that makes this a failure prone point for BMW's. If it was always vacuum, then there would be no problem with oil leaks. My solution was a small bead outside the o ring, and just a tad to set the ring its self. I know it is belt and suspenders, but it can't hurt if you are careful.
In summary, this is an easy one for those of you on the fence.
Old 03-11-2013, 07:15 PM
I also was sparse in my use of Permatex. I used just enough to hold the Gasket in the channel. As has been mentioned it is needed to set it in and keep it there. Last thing I would want is to have it partially pop out as I was seating the Pump back on to the engine. To have that gasket end up pinched and compromised after all that would tick me off!!!
Old 03-11-2013, 08:11 PM
Nitrogen's Avatar
My tips.
No more leak.
Nice addition to the post!!!! I never thought that the engine would turn by just using the belt
good to know. I also used permatex as long as it doesn't get inside the pump you are good! Nice job!!! Cheers!!
Old 03-11-2013, 08:15 PM
Nitrogen's Avatar
Hey tampamark the fish tail thing was me a few posts up...I remember fighting with it and it reminded me of that and it was the best way to describe it!! But your 100% right if not vertical you will be fighting that longer than doing the whole job!!!
Old 03-11-2013, 08:28 PM
haha, knew I read it somewhere and it stuck with me.
Old 07-16-2015, 05:40 PM
QuickSix QuickSix is offline
Mein Auto: 2005 645ci
How do I turn this engine with just the belt? You guys make it sound easy...
Old 07-16-2015, 07:24 PM
HerbP HerbP is offline
Take a socket & ratchet to the bottom pulley bolt, then turn the engine either way to line the notch up. Make sure the pump fits flush, or it could possibly crack the housing while tightening.
Old 07-17-2015, 07:02 AM
if you have the socket handy, that is a good solution. But I found that I was able to turn it by pulling the serpentine as it came off the bottom of balancer, and pushed the top of the balancer. A good solid push on top, and pull on the belt, and the engine turned fine... and I'm not a body builder. Just use your body weight and remember, you are only looking for a couple of degrees rotation.
Old 07-17-2015, 07:40 AM
Thanks for the responses guys. My brother actually had a breaker bar and a 1-1/16" socket that fit perfect. Got it vertical and got 'er done.
