6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations. |
Time to code the fog lamps. Anyone know how?
Started my car this morning and got this:
"Left front fog lamp malfunction. Have lamp check by nearest BMW stealer." The fogs are taped up and stuffed in the bumper. Maybe the bulb is dead from age? Anyway, when they did the bumpers they obviously didn't disable the lights. So does anyone know how to disable the fogs or should I start the search? LMA module I would assume?
'07 650i Coupe - Black Sapphire Metallic M6 bumpers, skirts & wheels BMW M Cross Spoke Composite 101 Rims 20" HUD, Comfort Access |
You need to turn off the Hot & Cold monitoring, you are correct, in the LMA. Here are the paprameters in question:
KALTUEBERWACHUNG_NSW_L COLD MONITORING OF LEFT FRONT FOG LIGHT nicht_aktiv not enabled aktiv enabled KALTUEBERWACHUNG_NSW_R COLD MONITORING OF RIGHT FRONT FOG LIGHT nicht_aktiv not enabled aktiv enabled WARMUEBERWACHUNG_NSW_L HOT MONITORING OF LEFT FRONT FOG LIGHT nicht_aktiv not enabled aktiv enabled WARMUEBERWACHUNG_NSW_R HOT MONITORING OF RIGHT FRONT FOG LIGHT nicht_aktiv not enabled aktiv enabled You should also disable check control for them too: FEHLERMELDUNG_CC_NSW_L CHECK CONTROL NOTIFICATION FOR LEFT FRONT FOG LIGHT nicht_aktiv not enabled aktiv enabled FEHLERMELDUNG_CC_NSW_R CHECK CONTROL NOTIFICATION FOR RIGHT FRONT FOG LIGHT nicht_aktiv not enabled aktiv enabled |
Once again, Rebel Ranter you're my hero. You just saved me a couple of hours of reading and searching. One of these days I need to come to Cork and buy you a beverage. If you're ever near Philadelphia, they're on me.
Couls not find the last two. These are the ones it has for FEHLERMELDUNG:
FEHLERMELDUNG_CC_FL_L aktiv FEHLERMELDUNG_CC_FL_R aktiv FEHLERMELDUNG_CC_AL_L aktiv FEHLERMELDUNG_CC_AL_R aktiv FEHLERMELDUNG_CC_SL_V_L aktiv FEHLERMELDUNG_CC_SL_V_R aktiv FEHLERMELDUNG_CC_BLK_V_L aktiv FEHLERMELDUNG_CC_BLK_V_R aktiv FEHLERMELDUNG_CC_BLK_H_L aktiv FEHLERMELDUNG_CC_BLK_H_R aktiv ALC_ERR_NSW_ZUSCHALTEN aktiv ALC_CC_127_ZUST_5_OFF aktiv ALC_CC_AL_OFF nicht_aktiv FEHLERMELD_CC_RL_BL_2_L nicht_aktiv FEHLERMELD_CC_RL_BL_2_R nicht_aktiv FEHLERMELDUNG_CC_KZL_L aktiv FEHLERMELDUNG_CC_KZL_R aktiv
