Old 02-15-2013, 06:21 PM
HDEddie1's Avatar
HDEddie1 HDEddie1 is offline
Mein Auto: F10 550i, E60528i
Maybe not too bad...
The quest for bar sizes, at least for me, is to simulate what the factory did for the F10 M5 platform. That route, at least, has some engineering in it. Notwithstanding the added benefits of the M5's different shocks, springs, and maybe link geometry, the use of M5 sized bars might, in themselves, deliver much flatter handling that our F10 so sorely lack (unless you already have ARS, DDC, and lowered springs).
Yes, a rear bar only install might provoke some surprises but perhaps not on the level you experienced on on 240Z. Our F10 from the factory have dialed in pronounced understeer and so much float and sway. I would be surprised if one chose the 16mm rear bar for a 535i and even the 18mm rear bar for the front heavy 550i that the infamous 930 oversteer situation would occur.
But, still a good point to consider when doing rear bar only. But to remove all doubt, at least for me , balancing the sway bar upgrade with a front and rear at the same time is the way to go.
My question on what the diameter of the front bar compared to the M5 front bar is just curiosity...how much did the BMW engineers increase the bar set, front and rear, over a non-M5. Just curious.
Originally Posted by quackbury View Post
OMG don't do that! When I was young and stupid (19) I ordered front and rear bars for my 240Z. I did the install myself. The front was more complicated, so I started with the rear, then took her for a test drive.
The rear turned my Z into a 930 Turbo clone. Worst TTO I have EVER experienced, even during my subsequent ling tenure as a PCA driving instructor. Thank God the pavement was dry that day, and I survived. My underwear did not.
BTW a lot of folks just seem to be focusing on the thickness of the bars. That is not the only important criteria. E.g. are the various bars solid or tubular? A tubular 14mm will likely be stiffer than a solid 18mm. Get all your facts straight before you start burning through shop time. Or worse, guard rails.
Sent from my HTC Inspire using BimmerApp
Old 02-15-2013, 08:26 PM
Alan L. Alan L. is offline
Mein Auto: LCI 550i Msport
Originally Posted by HDEddie1 View Post
Hi Alan,
Just wondering if you knew...what was the diameter difference between your stock front bar and the new M5front bar you have installed? Thanks
I don't since I haven't found anywhere that lists what my stock front bar is or the M5 one. I do know that visually you can tell right away the M5 bar is thicker for sure. My mechanic said the same thing once he looked at it.
Alan
Old 02-15-2013, 10:26 PM
HDEddie1's Avatar
The diameter should be listed right on the yellow bar code sticker stuck on the center of the bar. It'll be a number with a slashed O (symbol for diameter) following it. You'll see it on your old bar if you kept it.
Its too late now but when you were doing the install it would have been easy to read the number off the M5 bar before the belly pan was re-fastened. My guess is that the front bar is increased the same amount the rear bar is...4mm (from 14 to 18mm).
I look for the info when I do my bars. In the meantime, just curious.
Thanks the same
Alan
Old 02-15-2013, 11:28 PM
CyclePath1's Avatar
CyclePath1 CyclePath1 is offline
Ride On!
Mein Auto: 2012 535i MSport
I'm in for the M5 front/? rear sway bar combo once we confirm the rears.
I'll also be in for the ACS if we can get a groupbuy together.
Sent from my HTC VLE_U using Bimmer App
BMWCCA #474327
2012 F10 535i MSport
mods: Vollkommen front lip|M5 grill|M5 exhaust|M5 diffuser|Vibrant resonator|BMS stage 1|ACS springs|Suntek full front-end clearbra|FormulaOne Pinnacle tint 35%|clear reflectors|rear fog light switch|JBL ms-8 audio processor|Morel subwoofer
Old 02-16-2013, 04:58 AM
BigDeep1's Avatar
BigDeep1 BigDeep1 is offline
Festaholic
Mein Auto: 2011 535i Sport
Originally Posted by Supercomputers View Post
I am in if you can do an ACS buy, Labor all depends on shop location ect. Seems most of the guys who do them often are 350 in North NJ area.
Originally Posted by v12 View Post
So I spoke with the distributor yesterday in Europe about the ACS springs.
Says not a good group-buy candidate - not enough margin/ room.
They also have inventory constraints and it would be weeks before shipping.
Here is the ACS website to look-up the parts number based on car models: RWD/ AWD
I am having look into the M5 front sway bar.
Best I was able to find so far is $254 shipped - no taxes except MD from someone here in the US. Need 10 buyers to trigger that price.
There is definitely enough people interested in the ACS springs for a group buy. Are we sure that a group buy won't work for this item?
We can finazlize the group buy on the sways once we figure out all that info. I have a feeling the sway group buy will take a lot more time to get in place.
ACS Group Buy:
1. BigDeep1
2. CyclePimps
3. Rico
4. Gre8tW8LL
5. douggie
6. V12
7. Supercomputer
8. ???...
2011 535i Sport (Prem 1, 2)
Old 02-16-2013, 06:01 AM
octopump's Avatar
octopump octopump is offline
Brevity = soul of wit
Mein Auto: F10
ACS Group Buy:
1. BigDeep1
2. CyclePimps
3. Rico
4. Gre8tW8LL
5. douggie
6. V12
7. Supercomputer
8. ???...
The distributors I have been talking to explained there isn't enough margin on the ACS springs for the F10 to cut-in a group-buy.
I am sure someone could work for a $20-30 profit if they wanted to, but no one can be bothered for the time/ logistics work involved.
I would say for the springs, we would be better off ordering individually.
We would also need at least 10 buyers anyway.
A group-buy for the sway bars is possible however. There are prob. 10 buyers on this thread and a discount can be extended to us.
I also created a group-buy thread for the OEM BMW White Lines Tail Lights 1-2 weeks ago.
Old 02-16-2013, 07:22 AM
HDEddie1's Avatar
My kind of group!
Count me in on the ASC group buy.
ACS Group Buy:
1. BigDeep1
2. CyclePimps
3. Rico
4. Gre8tW8LL
5. douggie
6. V12
7. Supercomputer
8.
HDEddie1
9. ???
Old 02-16-2013, 09:27 AM
snj1013 snj1013 is offline
Mein Auto: 2011 528i
Thanks the same
The front is thicker. I believe the front sway bar on my 528i is 24mm where the rear is 14mm.
Old 02-16-2013, 03:50 PM
HDEddie1's Avatar
Thanks! Nice to know.
My guess is the front M5 bar will be 28mm, a 4 mm increase. That's plausible considering the rear M5 bar spec is 18mm, a 4mm upgrade from our stock rear bars.
We'll see...It'll be what it'l be but I was just curious.
Old 02-16-2013, 04:11 PM
Kcustom Kcustom is offline
Mein Auto: 2013 550ix
If I only have sport package will the bar fit?..... thanks
2014 335ix
Retired:
2013 550ix
2009 535i
2007 335i
Old 02-16-2013, 06:09 PM
HDEddie1's Avatar
Without ARS, then YES
If you do not have Active Roll Stabilization, which for 2012 was part of the DHP (Dynamic Handling Package), then your car, like mine, have the one piece solid sway bar front and rear, which IS replaceable by the M5 front (one piece) sway bar upgrade and possibly (soon to be confirmed) the F07 (GT) rear sway bar.
This whole sway bar upgrade quest is for us F10 owners who did not get the excellent ARS option and now wish we had more roll control.
BTW...if you're not sure if you have ARS, look under the rear of the car. If the sway bar looks one piece, then you don't. If it looks like two pieces, with a pneumatic control housing separating the rear bar into two halves, then you do. And lucky you because by design, ARS would negate the need for bigger sway bars anyway.
Old 02-16-2013, 06:29 PM
Bmwonly Bmwonly is offline
Mein Auto: F12 M6, F01 B7
I checked my 2013 M5 rear bar which is 18mm, so F10 5xx can use front M5 bar + GT rear bar, so how about M5 springs? can they use M5 springs and stock shocks? then this will be 95% M5?
Old 02-16-2013, 06:46 PM
Thank you very much for the info.... I will be adding it to the list of mods I am in the process of completing.... front and rear great news. I have the Dinan stage 2 in the plan after exhaust, spoiler, and M5 diffuser is complete. Thanks again
2014 335ix
Retired:
2013 550ix
2009 535i
2007 335i
Old 02-16-2013, 07:35 PM
HDEddie1's Avatar
Well, maybe not 95%...
If it were only that easy...I'm not sure if the M5 springs/shocks are a retro bolt on but even if it were, I understand that the M5 gets specific electronic tuning (via the DDC) not to mention changes to the link geometry, steering calibration, specific tire/wheel combinations, all tying everything together so it handles like a, well, "ultimate driving machine".
So for me, if I could achieve HALF of the M5 cornering ability with just spring/sways upgrades (already have DDC) in my floating non-M, I'd be a happy camper.
Old 02-17-2013, 02:10 PM
These are a couple pics of my rear sway 550ix
Sent from my SCH-I535 using Bimmer App
ID:	362733   Click image for larger version
2014 335ix
Retired:
2013 550ix
2009 535i
2007 335i
Old 02-17-2013, 04:32 PM
Supercomputers Supercomputers is offline
Mein Auto: 2012 550IX M Sport
SCHMIEDMANN with give us 5% off of the website price I think I am stearing towards Hartage,
I am in on the sways just waiting on conformation of the GT bar fitting and I am in. Would love to get the springs and sways all done at once,
Old 02-17-2013, 05:37 PM
HDEddie1's Avatar
Yep, just like mine...14mm rear. Can't wait to find out if the F07 bar upgrade fits.
Old 02-17-2013, 07:08 PM
If we can get a group buy on both I am in as well.... thanks to all for the research : )
2014 335ix
Retired:
2013 550ix
2009 535i
2007 335i
Old 02-18-2013, 06:19 PM
rhonig's Avatar
rhonig rhonig is offline
Mein Auto: 2014 X5 Diesel M Sport
Going to order the M5 front bar.
2016 M4, Silvertone, Black Anthracite Cloth/Leather, DCT, All other goodies
2013 535i, M Sport, Dark Graphite Metallic II, Oyster & Black Dakota Leather, 6 Speed Manual Transmission, M5 Front Anti Sway Bar, M550d/650i Rear Anti Sway Bar.
2014 X5 xDrive 35d, M Sport, Space Gray, Terra Dakota Leather, M Adaptive Suspension.
Old 02-18-2013, 07:06 PM
rhonig's Avatar
I just ordered the front M5 front anti sway bar from Tischer BMW & will try it out, first, without upgrading the rear sway bar, awaiting confirmation of rear's fit & review by fellow forum members. I am not going with modding the springs or shocks, as I like the basic ride on our local lousy streets & I don't think I want the car lowered any. I will report my impressions going forward.
Old 02-27-2013, 03:59 PM
Any updates boys?
Old 02-28-2013, 06:25 AM
Silververtu Silververtu is offline
Mein Auto: 2013 550i M Sport
The F07 rear sway bar does not fit on 550i.
2013 BMW 550i M Sport SAT
Gone But Not Forgotten:
2006 AUDI 2.0T A4 Avant, 2007 BMW Z4 3.0si Roadster, 2006 BMW M Roadster
Old 02-28-2013, 07:26 AM
Nison's Avatar
Nison Nison is offline
Mein Auto: 2011 535i xdrive
do you know how thick is the 550i rear sway bar?
Old 02-28-2013, 08:04 AM
Mr. Grumpy's Avatar
Mr. Grumpy Mr. Grumpy is offline
BMW Freak
Any updates boys?
The F07 rear sway bar does not fit the F10's. Alan recommended the M550d rear sway bar which is 16mm. The part was ordered and we're all just waiting for Joe@ptech to confirm that is a fit.
Coming Soon: 2017 540i Carbon Black, Black Interior, Fineline Ridge Wood Trim,
Retired: 2009 328i Titanium Silver, Black Interior, Dark Wood Trim, ZPP, ZLP, 609, 494, AAW Tune.
_______2011 535i Imperial Blue, Oyster/Black Interior, Anthracite Wood Trim, ZSP, ZPP, ZP2, ZCV, 2TB, 6NF, 6NR.
Old 02-28-2013, 08:41 AM
Alecop77 Alecop77 is offline
Mein Auto: 2011 535xi
I'd be in too...
Front and rear sways. Has someone started investigating a group buy?
2014 535xi | ZCW, ZDA, ZMM, ZPP, Z06, DHP, SAT, H-K, Carbon Black Msport
