Old 02-28-2013, 09:49 AM
HDEddie1's Avatar
HDEddie1 HDEddie1 is offline
Mein Auto: F10 550i, E60528i
See post 115 & 117
Yes, its only 14.0mm.
Originally Posted by Nison View Post
do you know how thick is the 550i rear sway bar?
Old 03-03-2013, 06:25 PM
dsnray dsnray is offline
Mein Auto: 2012 535xi Msport
Originally Posted by Alan L. View Post
Confirmed!! The M5 front sway bar is a direct fit for my 2013 535xi!!
All I have to say is wow and everyone must do this. This is how the car should have came stock. My car has DDC and ACS springs and I am in sport mode 99.9% of the time. Before the M5 sway bar I would rate the handling of my F10 a 4 or 5 out of 10 at best compared to my previous E46 and E90 on coilovers but now its a solid 7.
The suspension just feels tighter and more solid up front and you notice this when going over bumps and uneven roads. The car is flatter during turns and the steering feels alittle more direct/precise during high speed lane changes. Before I would anticipate the roll/sway movement but now the car just points to where you want it. It isn't a track car by any means but that wallowing feeling is pretty much gone or barely noticeable anymore. Nothing negative about doing this mod at all so far. Very pleased.
Another member already verified it also fits his 550i so it is safe to say this works on all F10's regardless if its rwd or awd.
Alan
I got the front sway installed as well. I definitely could feel the difference at higher speeds and when driving in the highway, but not much for normal driving on local roads (not that I expected much difference on local roads).
Btw Alan, I got my bar installed in the same place as you in Brooklyn.
Old 03-04-2013, 11:36 AM
Alan L. Alan L. is offline
Mein Auto: LCI 550i Msport
^^ Nice! I'm assuming Alex worked on your car? He's the only one there that touches my car aside from the owner himself.
You notice the most on the highway during high speed lane changes and curves.
Alan
Old 03-04-2013, 01:38 PM
Silververtu Silververtu is offline
Mein Auto: 2013 550i M Sport
Alan, are you going to add Dinan Shockware on your car?
2013 BMW 550i M Sport SAT
Gone But Not Forgotten:
2006 AUDI 2.0T A4 Avant, 2007 BMW Z4 3.0si Roadster, 2006 BMW M Roadster
Old 03-04-2013, 02:00 PM
I wish but its not available for the 535
Old 03-04-2013, 03:37 PM
Nison's Avatar
Nison Nison is offline
Mein Auto: 2011 535i xdrive
what's going on with the 18mm M5 sway bars? should be a better fit than the F07 bar?
Originally Posted by Mr. Grumpy View Post
The F07 rear sway bar does not fit the F10's. Alan recommended the M550d rear sway bar which is 16mm. The part was ordered and we're all just waiting for Joe@ptech to confirm that is a fit.
Old 03-04-2013, 04:26 PM
Mr. Grumpy's Avatar
Mr. Grumpy Mr. Grumpy is offline
BMW Freak
Joe@ptech already tried the M5 rear bar but the links were not lining up.
2011 535i (07/2011 build) Imperial Blue, Oyster/Black Interior, Anthracite Wood Trim, ZSP, ZPP, ZP2, ZCV, 2TB, 6NF, 6NR.
Retired: 2009 328i,Titanium Silver, Black Interior, Dark Wood Trim, ZPP, ZLP, 609, 494, AAW Tune.
Old 03-04-2013, 05:31 PM
Nison's Avatar
Just did some research on real oem and found that the f11 m550d has a 18mm rear sway bar. Not sure if our dealers can get them here
Old 03-05-2013, 06:35 AM
Looks like this is it.
Old 03-05-2013, 03:07 PM
Alan
Alex was busy running around that day. He had one of the mechanics take care of it. No big deal as it was just a simple swap.
Yeah, it's most noticeable on curves like you said.
Old 04-03-2013, 01:58 PM
Nison's Avatar
got the 650i 16mm rear sway bar, but it turns out the bushings are not included as the m5 bars, and they are twice as much as the sway bar itself... ouch... fingers cross for the fitment
Old 04-05-2013, 02:18 AM
rhonig's Avatar
rhonig rhonig is offline
Mein Auto: 2014 X5 Diesel M Sport
I had the standard ZSP Sport Package front anti sway bar, measured at 23mm diameter replaced, yesterday, with the considerably stouter M5 one on my 2011 535i. This was done on a lift by a local BMW trained technician who works on BMWs & MINIs, exclusively, in his own shop. I'm glad I had him do it with his looking up propper bolt tightening torque values (quite tight) on a subscribed BMW website. He also installed a set of mud guards on the vehicle. The bar install took about a half hour's time.
Without having done any other suspension modification to the vehicle, this modification has greatly enhanced its handling and I highly recommend this relatively inexpensive modification under the classification of a "No-brainer."
I await direction as to which rear anti sway bar upgrade to install, the standard one looking little more than the diameter of a pencil. It looks like the replacement of the rear bar will require exhaust removal.
2016 M4, Silvertone, Black Anthracite Cloth/Leather, DCT, All other goodies
2013 535i, M Sport, Dark Graphite Metallic II, Oyster & Black Dakota Leather, 6 Speed Manual Transmission, M5 Front Anti Sway Bar, M550d/650i Rear Anti Sway Bar.
2014 X5 xDrive 35d, M Sport, Space Gray, Terra Dakota Leather, M Adaptive Suspension.
Old 04-05-2013, 07:47 AM
Originally Posted by rhonig View Post
I had the standard ZSP Sport Package front anti sway bar, measured at 23mm diameter replaced, yesterday, with the considerably stouter M5 one on my 2011 535i. This was done on a lift by a local BMW trained technician that works on BMWs & MINIs, exclusively, in his own shop. I'm glad I had him do it with his looking up propper bolt tightening torque (quite tight) on a subscribed BMW website. He also installed a set of mud guards on the vehicle. The bar install took about a half hour's time.
This is awesome to hear. Everyone with an F10 complaining about sloppy handling must do this mod. If people look on realoem.com the F10 comes with a wide range of front and rear sway bar sizes depending on options so it could have a even bigger impact on cars that don't already have the thickest stock bar from the factory.
Alan
Old 04-05-2013, 12:36 PM
HDEddie1's Avatar
Curious here...do you know what was the diameter of the M5 bar is? Thanks!
Old 04-05-2013, 02:45 PM
ausdude's Avatar
ausdude ausdude is offline
Mein Auto: 2013 BMW 550i M-Sport
What size bar did you use and do you have a link to it?
Thanks in advance
Untitled[/url] 550i M Sport|300|LCSW|4MR|2TB|704|760|PDC|ZEC|6F2|ZDA|5AD |416|494|Dinan Stage 2|CF Spoiler,MirrorCaps&Splitter|M Performance Diffuser|Front Reflector Delete|Black Grilles|Rear Fog Lights|Euro Side Mirrors&Tail Lights|M5 Front & M550D Rear Sway Bars|20" HB04|Roof Wrapped|Coded|CCA member
Old 04-06-2013, 07:42 AM
rhonig's Avatar
I purchased the bar at Tischer BMW/Get BMW Parts:
http://www.getbmwparts.com/partlocat...catalogid=4462
Insert part # 31352284460 in "Search Accessory Catalogs:" box & click on "Search"
I didn't measure the diameter of the M5 bar. Just the 23mm ZSP Sport Package one I replaced from my 535i, in case someone wanted to purchase it from me.
In the words of the Nike advertising phrase:
"Just Do It!"
Old 04-06-2013, 02:05 PM
BigDeep1's Avatar
BigDeep1 BigDeep1 is offline
Festaholic
Mein Auto: 2011 535i Sport
Awesome! Thanks Rhonig. So, this $254 sway bar is all that I need for the install?
2011 535i Sport (Prem 1, 2)
Old 04-06-2013, 03:20 PM
rhonig's Avatar
All parts are provided with the M5 anti sway bar or taken from the stock bar. The part was not in stock, at Tischer BMW, so delivery out of Germany was about 3 weeks at my time of ordering.
Old 04-06-2013, 03:43 PM
ausdude's Avatar
Thanks for the info!
Old 04-06-2013, 09:38 PM
Just got back from a nice long speedy drive and I am starting to really like the way this big sedan moves now. I can't reiterate it enough that this simple upgrade does wonders on the F10.
Alan
Old 04-08-2013, 02:46 PM
rhonig's Avatar
I decided to take a 3 year lease on an M Sport Package 6 MT 535i to be built shortly. Having experienced the M5 anti sway bar in my 2011 535i, I want to make sure it will work in the M Sport 535i if I order the "Dynamic Damper Control" or not to order the "Dynamic Damper Control" at all.
Old 04-08-2013, 09:25 PM
kc1953 kc1953 is offline
Mein Auto: 2012 535i.
Does installation of the M5 front sway bar have any adverse implications for the warranty on the car?
2012 535i, black sapphire metallic, oyster/black dakota, premium, premium sound, technology, sport, sport auto, heated front seats.
Old 04-08-2013, 09:52 PM
Nison's Avatar
if whatever happened to the front suspension you can always swap it back to stock bar before taking it in for warranty claim. only 30mins labor.
Old 04-08-2013, 10:06 PM
Diplomatic Diplomatic is offline
Had mine installed by the dealer, no warranty implications...
ACS Spings | ETG Stage 1
Old 04-09-2013, 07:13 AM
No. Frankly nobody is going to know the bar isn't stock just by looking at it. Unless the tech has another F10 next to it to compare they aren't going to know. Plus with all of the different packages the F10 comes in the front bar comes in all different sizes as is.
Alan
