Old 02-10-2013, 05:40 AM
starautomotive starautomotive is offline
Mein Auto: 5 series
blowing fuses
i have a 99 58i with codes p1721 & p1723 after diagnosing i found that the air injection pump was bad but the check valve was working fine. also there was no power getting to the pump so i replaced the pump and i found that fuse 107 under the carpet on the passenger side was blown. i put a new one started the car it worked fine for 2 key cycles and the it blew the fuse again, in between the fuse and the pump there is a relay has anyone ever see the relay blowing the 50 amp fuse for the pump? any help will be greatly appreciated.
Old 02-11-2013, 10:42 PM
vatoman vatoman is offline
Mein Auto: E39 I6
Check the ebox, under the passenger cabin filter. Open it up and check for water near the bottom. Pull the relay and inspect it too.
