leaking issue - Bimmerfest - BMW Forums
Old 12-31-2015, 06:23 AM
david y miller david y miller is offline
David
Mein Auto: 1985 635
leaking issue
El Nino has dampened the joy of new ownership of a 2005 E63.
Outside during an extending rain, the car's carpet under and behind the front passenger seat was soaked. It appeared the water came from behind the glove box.
Does anyone have experience and advise with this issue on E63 cars?
Old 12-31-2015, 06:48 AM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
It's a known issue with blocked scuttle drains. These are little rubber spouts that drain out water from underneath the areas under your microfilters. It also affects the e60 5 series. Here's a thread on the 5 Series, it will help understand the issue. My advice is to remove or push through the the rubber spouts.
http://forum.bmw5.co.uk/topic/71541-...cuttle-drains/
Video:
Current cars
1996 e36 320iC (convertible)
2006 e63 630i Sport w/SMG
2007 e63 M6
Previous Cars: 2002 e39 525iA Sport, 1994 e36 318i, 1990 e34 520i, 1989 e30 325i, 1986 e30 316
Old 12-31-2015, 07:12 AM
You can see the drain on the driver's side under the brake master cylinder (this is a right hand drive car in the picture):
I'm the passenger side a view of the drain is obscured by the ECU housing. I've seen posts suggest using a couple of straws end to end and blowing in to hear if the water gurgles!
Here is a shot of the offending runner spout that fill with grime and get blocked, allows water to accumulate and eventually overflow via a wiring portal in to the cabin of the car:
As I suggested above just remove them rather than clean them out, they will only fill with gunk again!
You could use an open metal hanger to push the spouts down in to the hole and that will be fine. If there's water in there watch out for your feet though!
Current cars
2007 e63 M6
Old 12-31-2015, 07:20 AM
David
Mein Auto: 1985 635
thanks. I greatly appreciate your response and advice.
Old 12-31-2015, 07:49 AM
Any time!
Have a quick check for wear on the door seals too. They are probably fine but worth checking.
The other area to consider is the sunroof drains getting blocked. Do you have the glass roof?
However in all likelihood its your scuttle drain spouts that are blocked.
Old 12-31-2015, 08:00 AM
David
Mein Auto: 1985 635
yes, I have the glass roof. I have the rubber floor mat on the passenger side, and could tell water had dripped on the top and moved down, assuming the water continued to the rear floor.
Old 01-01-2016, 08:36 PM
mrdm1 mrdm1 is offline
Mein Auto: 2006 BMW 650i 2003 hummer
I'm having this issue but I get in the trunk
Old 01-04-2016, 09:37 AM
gregb's Avatar
gregb gregb is offline
Mein Auto: 2014 BMW ///M6 vert
Do you own the convertible? If so the drains in the bottom of your vert top box are plugged and its about to ruin you amp/sat radio receiver! Do a search here as there are many threads, and address ASAP as you might have a chance at drying out/saving your electronics.
Regards, Greg
'14 M6 vert, san marino blue on amaro brown full merino leather, drivers' assistance, exec package, B&O sound system, CCB package, akra exhaust, tint, windscreen, etc.
'07 650i vert, beige/jet black, sports & cold weather pkgs, comfort access, etc.
'11 Acura MDX Advance with Entertainment pkg for wife - no mod's '04 Acura TSX (daughter) and '12 VW GTI - Autobahn (son)
Old 01-04-2016, 11:09 AM
HerbP HerbP is offline
Originally Posted by gregb View Post
Do you own the convertible? If so the drains in the bottom of your very top box are plugged and its about to ruin you amp/sat radio receiver! Do a search here as there are many threads, and address ASAP as you might have a chance at drying out/saving your electronics.
You are supposed to be at work! Hello Mark Richt!
Happy New Year
Old 01-04-2016, 12:54 PM
gregb's Avatar
Happy New Year
Hey Herb - I was on lunch break... but I'm supposed to be working right now! Generally quite pleased with the Richt hire (I think GA fans might be sorry if things don't work out as well as they hope). Happy New Year to you and yours as well!
Regards, Greg
Old 01-04-2016, 05:28 PM
I think it was time for a change. I am glad he got another good job, & I hope he can teach his new players some self discipline. He certainly has no problem with sitting down anyone that gets out of line. I wish all coaches had his morals. It would be good to see Miami & UGA meet in the national championship in the near future.
Old 01-07-2016, 07:36 AM
mee63 mee63 is offline
Mein Auto: 645/ HD Dyna/ 67 F100
Good info! Thanks! Theses cars are too nice to have wet carpets and condinsation all over the windows
Old 01-07-2016, 07:41 AM
Awe yes Rebel. Glass roof. It feel dry around the glass.
Old 01-07-2016, 08:05 AM
