E30 (1982 - 1993)
Old 02-03-2013, 10:37 AM
Stormint Stormint is offline
Mein Auto: e30 convertible
1990 326ic Refrigerant
Have a 90, 325ic which has the quick connect on the low pressure side which would lead me to believe that the refrigerant in the system is R134, but the Bently Manual says R-12 - HELP - what doe it have?
Old 02-03-2013, 10:52 AM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is online now
Mein Auto: 1989 E30; 2000 E38; GS350
The system came with R-12. If you have a R-134 quick connect on the low side, chances are someone changed over the refrigerant. If the system is not working, have it professionally converted... compressor oil, expansion valve, dryer, and refrigerant changed. Most time, the compressor is reused.
Big Boyz with Bad Toyz.
Old 02-03-2013, 11:42 AM
downhiller's Avatar
livin large
someone probably just released the r12 and threw in 134a.
as said before, get it properly done. dont just throw gas in and hope and pray
Old 02-03-2013, 05:19 PM
BMWFatherFigure's Avatar
Old School
+1 on above.
Current:
E38 Parts Car
Previous:
