7 Series - E38 (1995 - 2001)
740il sunroof will not open
I have a 1995 740il with a Sunroof that will start to open and then stop.
Any suggestions? |
Try initializing it. Press the sunroof button up and hold it there. It will move to a position and pause-keeping pressing the button during this pause and it will set off again. Just keep that button pressed until it stops a second time - IIRC that will be in the closed position. It should now operate normally.
If this doesn't work, repeat, but press/hold the butoon towards the rear of the car. Both methods can work |
Ditto chrisn7...if there's no broken mechanisms in the rails/tracks...then try reinitializing the roof panel...see the directions in the far right column under "power loss or malfunction":
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) |
I will try.
Thanks, Kevin |
Tried to reset. No change. Cannot figure out how to manually do it.
You could have debris caught up in the cables. It happened to me - some idiot with a loosing Lotto ticket. Needed the stealer to get it out.
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
How do I get to these cables?
You can manually open the sunroof using the "Z" shaped tool in your trunks tool kit. Remove the sunroof access panel, and the tool's hex-shape slides into a matching hex opening in the sunroof's motor. See #11 (the tool) and #6 (the sunroof motor) in the diagram below:
Click this link for more sunroof diagrams: http://bmwmobiletradition-onlinecom....30&hg=54&fg=05
![]() (sunroof tool) ![]()
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) Last edited by QSilver7; 02-07-2013 at 01:17 PM. |
I will give it a try.
Thanks, Kevin |
I'd use the stealer - they break it - their problem. (ok mine was under warranty at that time)
IT worked. Went back and forth back and forth, got easier everytime.
Now the electronics are working. Thanks! |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
