Old 02-04-2013, 12:17 AM
Zain1003 Zain1003 is offline
Mein Auto: 07 e90 335i w/ Sport Pkg
Opinions on wheel spacers
So i recently picked up a set of miro 380 staggered 18x8 and 18x9.
I am going to throw them on soon with 225 front and 255 rear tires.
I want a more aggressive look and am thinking about wheel spacers.
Because i dont know much about the subject i was looking to get some opinions from people who either know about it or have done it on their e90s
Id like to go as wide as 25-30mm in the back and probably 15-20mm in the front (i think that would look correct, right?)
I obviously do not want any rub, how ever i very rarely have people in my back seat.
I have an e90 335i with sport pkg that is no lower than it comes from the factory in said configuration.
Old 02-04-2013, 02:58 AM
Speedwagon's Avatar
Speedwagon Speedwagon is offline
Mein Auto: 2012 328IX Sportwagon
You will need to put the wheels on and then see how much space is remaining. Here is a link to help you! I have some on my E91 and haven't had any trouble, don't forget to get longer wheel studs.
http://www.turnermotorsport.com/t-wh...yclopedia.aspx
Old 02-04-2013, 03:06 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
I would predict that 20mm is about the most you could manage without rubbing (unless you roll your arches of course).
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof
Old 02-04-2013, 04:29 AM
CT's Avatar
CT CT is offline
GODSPD
Mein Auto: SSII E90 ///M, AW E92 N54
You won't be able to fit much more than 12mm up front and maybe 15mm rear unless you start adding camber, I think. But that depends on what the base offsets of those wheels are.
e90m / ssii / foxred / nochrome
wedssport sa-55m 19x9.5 et24 square / kwv3 / 15mm rear spacer
full challenge exhaust
WHEELS FOR SALE
Old 02-04-2013, 10:51 AM
I apologize I should have included the offsets. Et35 front and 38 rear.
So looks like I should go about 20mm rear max and 12mm front max? Hm. I guess I'll just put the wheels on first and then see how much space I have.
Old 02-04-2013, 10:55 AM
Thanks, I am not looking to roll my arches so hopefully I can do 20 in the back as I'd really like to!
Old 02-04-2013, 10:56 AM
That is extremely helpful thank you very much. Also, I am jealous of your e91
