E36 (1991 - 1999)
Old 02-04-2013, 02:52 PM
Kens BMW Kens BMW is offline
Mein Auto: 1999 323ic
P0306 #6 cylinder misfire
Ok so my 1999 323ic threw the P0306 engine code. I changed all spark plugs reset the code and went for a good day then pop back on. Should I go for the coil pack next or what? Any suggestions? Thanks
Old 02-04-2013, 03:36 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
swap the #6 coil pack with the #5 coil pack. if the fault moves to #5 then replace that coil. if it stays #6 then you have something else going on.
but do this first, then report back,
df
Old 02-05-2013, 04:53 AM
Ok so I swapped out the coil packs on #5 and #6 cylinders. I'll let you all know what happens. I'm hoping it comes down to a bad coil pack.
Old 02-05-2013, 05:21 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
And if it is the coil pack, stay away from the Bav Auto coil packs. You'd be better off just pouring sand into the cylinders than using their coil packs.
Old 02-05-2013, 06:03 AM
SCJon SCJon is offline
Poet of Signature Quotes
Mein Auto: 1997 BMW 328is
Easy! I have BavAuto coil packs and don't have too much of an issue with them. But to the OP just remember a wise man once said "Guessing gets expensive" (df) so I wouldn't replace anything you aren't sure you need to replace.
"It doesn't do any good for me to know more than you if you aren't going to listen to me"
Originally Posted by petriej View Post
So let it be written, so let it be done.
Old 02-05-2013, 07:33 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
wait... aren't you having a random misfire issue? Not to thread jack...
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 02-05-2013, 07:43 AM
I am but it stays on cylinder #1 even when I switch the coils. So I've pretty much eliminated them as a suspect. I think...
Old 02-05-2013, 09:10 AM
So SCJon whats your next step since you swapped the coil packs?
Old 02-05-2013, 09:30 AM
Between me and the previous owner nearly everything has been tried. My next step is going to be a compression test. If I can ever get around to it. But my car does not actually miss, it runs normally except once in a while it actually misses, but turning it off and restarting it causes the miss to disappear.
Old 02-05-2013, 11:24 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Intermittent misses are just the worst. If you are brave, try removing and inspecting the crankshaft position sensor. My 6er (different breed, I know!) had a whacky one that would intermittently fail and cause a miss. It was covered in metal shavings that kept it from reading the flywheel correctly and would cut fuel.
Probably not your issue, but like you've said, you've tried nearly everything.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 02-05-2013, 12:04 PM
One of the BMW dealers in Raleigh even said that it was possible that the computer was set to European standard and the American coils had fouled it up. I seriously doubt that's it. But even they resorted to that level of ingenuity trying to figure it out. For me it's more frustrating than anything else, just like you said. It just makes me nervous sometimes when I drive it and it does miss. Thanks for the tip. I don't know if I have the stomach for the CPS yet though. I may resort to it eventually.
Old 02-05-2013, 03:30 PM
wait, wut??
coils no sprechen ze deutsch??
maybe it was metric spark not sae spark??
df
Old 02-06-2013, 07:13 AM
Originally Posted by drivinfaster View Post
wait, wut??
df
I'm right there with you on the oddity of that diagnosis. They were clearly reaching and wanted Sean (my PO) to flash the computer. He knew the comp had no governor on it from driving it Germany and he declined. So I may just look for a set of OEM coils and try it if I can get some at the junkyard cheap, but I don't think they are to blame. At this point, I'm leaning toward the ever so slightly off spray pattern in injector #1 as the culprit.
Old 02-10-2013, 05:06 PM
Ok so quick update. I swapped #5 and #6 coil packs and no check engine light yet. Its been at least 4 days. However the car is running a little rough What the hell?!?! I figured we would have got the check engine light back on either telling me bad coil pack or something else. Since its running rough I'm not sure if I should change the fuel filter, Injectors, or what?
Old 02-10-2013, 05:16 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
First things I would change:
Plugs
air filter
Fuel filter.
They are cheap and basic maintenance regardless.
Get more complicated only after you have eliminated the simple.
Sent from my U8651T using Bimmer App
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 02-10-2013, 05:41 PM
All plugs have been replaced so I'll move on to the fuel and air filters and see were that gets me. But it still baffles me why that check engine light hasnt popped on yet
Old 02-10-2013, 05:48 PM
jonesin's Avatar
The Canadian Prick.
To be certain, what plugs did you use?
Old 02-10-2013, 05:53 PM
I used what was recommended on this forum, the NGK BKR6EK
Old 02-10-2013, 05:54 PM
jonesin's Avatar
The Canadian Prick.
Perfect.
Just making sure you didn't get Bosch +4 Platinums.
Old 03-05-2013, 01:27 PM
Its back, P0306 code
Its back, the dreaded P0306 #6 cyclinder misfire. I swapped the #6 coil pack with the #5 and actually went a whole month without the coded. Then all of a sudden it pops on today Ok so its not the coil pack. All spark plugs have been changed. Whats next, the injectors?? I think I'm running out of things to change!! Any more adviced?
Old 03-05-2013, 01:29 PM
petriej's Avatar
Do some inspection first. Is there anything in the spark plug socket, like oil, water, etc.?
Do a compression test. You might have a faulty head gasket or valve cover gasket.
GGC BMW CCA #443004
Join the BMW CCA!
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
What condition are your coil boots in? Are they cracked, oily, or have discolored contacts?
1998 BMW 328is
1966 Pontiac GTO
Old 03-05-2013, 01:31 PM
Nope, No oil at all in the plug sockets. I made sure to look at them all when I changed them.
