E30 (1982 - 1993)
Old 02-04-2013, 06:36 PM
Microtesties Microtesties is offline
Unregistered User
Mein Auto: 1990 BMW 525i
Headers
Hello everyone! I'm here today to ask a few questions about headers. First of all, I drive an E34 525i with an M20 engine, and since 90% of E34s are M50 I figured I'd go here, to the pros! Anyway, back on topic, I've started to really get into upgrading my car, and without a better flowing exhaust it can only be so good. To make this pretty here are my questions:
-What headers would you suggest? (E34, so space is no issue)
-In order to install headers, do I need to remove the head?
-What kind of gains should I expect to see? (If my engine were completely stock)
-What should I expect to pay for the entire job? (I do all work myself)
-Some headers place the O2 sensor so it only reads half the cylinders, is that okay?
Thank you all for your input!
Year: 1990
Model: 525i
Transmission: 5 speed
Mileage: 250k
Old 02-05-2013, 05:25 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Post Exhaust 101
Firstly, not all headers are created equal
I design my headers around displacement, stroke, cam and the power characteristics my client wants.
Secondly, the header works in conjunction with the rest of the exhaust, so I'd rather get a matched set
That said, if you run a stock M20 anything you do to it will be rewarded
I normally design the headers to make up for some of the lost bottom-end torque from the cam I use.
Headers & systems should be bolt in !
The manufacturer should tell you what gains to expect ! Since all set-ups are different, it often becomes a case of one lying a little more to outdo the other
I would charge you about 8000 Rand for a complete system, to give you an indication
Read your plugs after having fitted everything, and put the O2 sensor in the richest pipe. Easier said than done
Your Lambda sond tries to adjust your motor at cruising to stoichiometric (to satisfy legislation), which is too rich for economy
So the location, in your case, is only important for it to run within operating temperature parameters.
Hope not to have confused you
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 02-05-2013, 06:13 PM
Unregistered User
Well I can't afford to get custom made headers unfortunately so I've been searching online for some. Thing is the only ones I can really find are from Ireland Engineering and OBX, IE headers just look cheap OBXs are actually cheap . It seems like any time I find ones that seem really nice they're either grossly expensive, weld on, or discontinued...
If it's of any assistance my engine is lightly modified. So far what I have is a 2.7" MAF conversion, performance chip, adjustable fuel pressure regulator, and a high flow fuel pump. A few future investments I plan to make are things like fuel injectors, and of course headers.
Also I MIGHT get into more involved upgrades in the far future.
-Lightweight flywheel (next clutch change)
-More aggressive camshaft (next belt change)
-Upgraded radiator and fan delete
-Oil cooler
So if you know of any manufactured headers that are good, I would love to hear your suggestions!
Year: 1990
Model: 525i
Mileage: 250k
Old 02-06-2013, 01:22 AM
BMWFatherFigure's Avatar
Old School
Try and get dyno graphs from the header manufacturers. Have your existing injectors rig cleaned and tested.
Current:
E38 Parts Car
Previous:
Old 02-07-2013, 11:37 PM
Nick323's Avatar
Nick's Toys
I agree with father figure, but sadly a lot of unscroupulous operators publish Dyno figures that have no meaning
maybe also check the web for a shootout ???
Old 02-15-2013, 12:44 AM
fporro fporro is offline
Send a message via MSN to fporro Send a message via Yahoo to fporro
Mein Auto: 87 325iC
There's so many to choose from depending on your goals and budget, here's some candy from RD ...
http://e30motorwerks.com/index/produ.../16-rd-headers
cheers,
Frank
e30 parts
