E60 (2004 - 2010)
Old 02-04-2013, 08:09 PM
Rob3980 Rob3980 is offline
Mein Auto: 2008 BMW 535xi
Tail Lights
So i found a set of black tail lights here
http://www.protuninglab.com/04bmwe60...tm_content=pla
and what im wondering is are the taillights from the 04-07 5 series that same as the 08s ? so basically would these work on my 08 535xi?
Old 02-04-2013, 10:26 PM
40 views and nobody can answer this for me ???
Old 02-05-2013, 07:15 AM
GOR777's Avatar
GOR777 GOR777 is offline
Mein Auto: 2007 BMW 550I
I think it is just pointless to go back in time
Why would someone with LCI lights go back to aftermarket wanna be LCI lights?
http://tinypic.com/r/vwzua1/6
Old 02-05-2013, 07:36 AM
Frenchyrider267 Frenchyrider267 is offline
Frenchy
Mein Auto: 2004 525i
I'm sure u probably thought of this, but maybe find someone with an 07 and see if the harness is different some how. I would guess there probably is. Just going off of my knowledge from searching for parts for my 2004 E60 that around 07-08 they changed little things on the E60. i.e. lightbulbs. I wouldn't doubt that wire harnesses could have been one of them. That's probably why they only list from 04-07. On realoem.com I noticed also that other parts were "ENDED" and there were newer parts in its place.
Old 02-07-2013, 09:49 PM
Frenchy
So? Did you figure out if they were good or not?
Old 02-07-2013, 09:59 PM
1naztyx5's Avatar
1naztyx5 1naztyx5 is offline
Mein Auto: E70 X5/E60 528i
Get a vinyl overlay or spray night shades and be done with it
Old 02-07-2013, 10:01 PM
dwlink dwlink is offline
Mein Auto: 530i
Did you try asking the vendor this question? If anyone should know, they will.
2004 BMW 530i (his) -Titanium Silver -Grey Dakota -Dark Poplar -Premium -Sport -Cold Weather -Xenons -Heated Rear Seats -Active Steering -Logic 7 -Sirius
2010 Lexus RX350 AWD (hers) -Smokey Granite Mica -Black -Premium -Comfort -Nav -Tow Prep -Premium Sound -Wood Steering Wheel/Shifter
Old 02-07-2013, 10:33 PM
booyaazaa's Avatar
booyaazaa booyaazaa is offline
Mein Auto: '09 AW 535i
No it will not be a simple PnP. Those lights are designed to plug into a pre-lci harness and your 535i is a lci. If you are trying to get the smoked effect you can try to tint the tail light to give it the smoked look.
2009 AW 535i
-Sport, Premium Package, and Comfort Access
-20" Forgestar F14 Black Gloss, Cobb PTF E30 map, KW V2 CO's, Remus Sport Exhaust, BMS DCI, RPI Scoop, Full Front 3M PPF, 35% tint all-around, Orion V4's, Bruce v6.1L cables, LED interior lights, WeissLicht License Plate LED, Trinity Smoked LED side markers, Bimmian Smoked Reflectors, OEM black gloss grills, and Invisibulb turn bulbs.
Old 02-08-2013, 03:52 AM
07s will not work it's a different harness the car goes in for tint and the Taillights are being sprayed today as well
Performance: JB4 G5 ISO / BMS DCI / AR DP's / BMS WW Meth kit / ER CP / ER FMIC / HKS BOV / BMS OCC
Exterior: Avant Garde M310 wheels / Window tint / mtech halo upgrade / Sprayed tail lights & side markers / M5 front and sides / Front Lip Spoiler / Kidney Grills / Black BMW logos / LEDS
Interior: Custom gauges done by Simon
Soon to come: RB Turbos / V3 coil overs
Old 04-30-2013, 09:08 PM
Frenchy
Tail Lights
Are there any other sites to purchase these whole LED taillights besides ProTuningLab. They are all out of stock.....:-/
Old 05-01-2013, 06:00 AM
Image2Pixel Image2Pixel is offline
Mein Auto: 528i xDrive
One thing you need to be careful of when installing aftermarket taillights is the sealing. OEM parts fit properly and unless damaged won't let water in. With aftermarket lights, I would be careful. It is the same as getting aftermarket sheet metal parts for the body. They typically never fit the same. I also think it would be much better to tint the OEM parts, if that is the look you want.
Old 05-01-2013, 06:54 AM
I ended up just spraying the taillights to get the look I wanted
