Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 02-05-2013, 09:33 AM
southbeachm3 southbeachm3 is offline
Mein Auto: E36 M3/2/5
Stripped thread where bottom bolt of serp belt tensioner goes. Please Advise
Hi Guys, any advice would be great. This is for a 95 M3.
So I was torquing down the bottom bolt of the hydraulic tensioner (the one for the serpentine belt) and to my knowledge, per my Bentley Manual the bolt is an M8.8 and thus 18 ft/lbs of torque would be ok... I barely got a few turns in (nowhere near enough to be 18 ft/lbs) and it spun...? I took out the bolt and saw that I stripped maybe 2-3 threads.
So the bolt was flush even when spinning, which means it couldnt grab any more thread right? in other words, its too short? but then again BMW made it that way for a reason...? Im thinking go to the dealer and get a few bolts that are the same diameter maybe just a little bit longer to just secure it in place. What do you guys think?
Also, is the thread I stripped in the base plate? or on the engine block? :/
Thanks in advance!
I attached a few pictures for reference.
ID:	360904   Click image for larger version
Old 02-05-2013, 12:32 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
I'd repost this in the E36 forum. I'm not sure if you're screwed, or REALLY screwed. Probably neither. Might need to retap it.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 02-05-2013, 08:48 PM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
I would look into a heli-coil type insert where you can use the same size hardware.
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
