X5 E53 (1999 - 2006)
The X5 SAV Forum |
Mechanic is charging $440 to replace front right wheel speed sensor
Is that a reasonable price?!
I have a 2001 model, if that means anything
Indy or dealer? Did he give you a break out on parts and labor?
Indy, and no he did not. Agh, I should have asked.
Huh, speed sensor? Never heard of it. If you can find out what part it is check the price on http://www.realoem.com/bmw/select.do?vin=XXXXXXX (substitute the last 7 of your VIN for XXXXXXX in the link)
Colby, [Dead] 2001 X5 4.4i w/ 139K miles (probable cracked engine block) 2005 X5 4.4i w/ 97K miles |
Go to ECStuning.com and buy the sensor ,Jack up the car and support it with jack stand ,,,,,,and about an hour later waola you done, and save your self $ 300 that should be enough to buy you tons of beer ...
http://www.flickr.com/photos/mrbmwx5...n/photostream/ http://www.flickr.com/photos/mrbmwx5...n/photostream/ http://www.flickr.com/photos/mrbmwx5...n/photostream/
![]() 2001 X5 3.0i 200k miles & counting...( SOLD) Dinan Stage 1 Trans and Engine /SMG M3 Steering wheel/M5 SMG shifter/BMW rear entertainment/4.6IS body kit/4.8is Exhaust/ X-pipe/Turner HP Pulleys/E92 sport seats/Group M Intake/Brembo drilled rotors/Quart projector beams headlights 06 750Li with 19k miles. Bone stock. Last edited by mrbmwx5; 02-06-2013 at 03:35 PM. |
You 'can' test them, by the way.
- How to test the BMW wheel speed sensors with a DMM (1) Here are my results, for example, from a few years ago:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
Or you can connect a laptop with INPA on it and see which wheel is not sending data back to the ECU.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
