Old 02-05-2013, 07:00 PM
niko14 niko14 is offline
Mein Auto: F10 M5
FSC Activation Code
ok i have a Sirius FSC activation code for my F10 M5. How do i go about activating it ?
Assuming i do the following: Esys comfort mode and use upgrade FSC ??? what VO do i specify ?
Any direction appreciated.
Old 02-13-2013, 04:16 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Well, that is the basic idea, but only the tip of the iceberg.
When you got your SAT Radio FSC Code, you should have received 3 files:
e.g. xxxxxxx_006F0001.xml
e.g. xxxxxxx_006F0001.der (FSC Code Certificate)
e.g. xxxxxxx_006F0001.fsc (FSC Code)
E-Sys => Options => Settings => FSC Tab => Certificate Field:
Load FSC Code Certificate (e.g. xxxxxxx_006F0001.der)
E-Sys => Comfort Mode => FSC => FSC Field:
Load FSC Code (e.g. xxxxxxx_006F0001.fsc. The FSC Code file must first be Base 64 Decoded or else E-Sys can not read it. (Use B64Dec for Decoding - http://4mhz.de/b64dec.html).
FA Field: Select "Read FA" to use cars current VO.
Parameter Fields: (Example for Sat Radio FSC Code and CIC):
Diagnostic Address (hex) = 63 (99 in Decimal for HU_CIC; I think the same for HU_NBT)
Application Number (dec) = 111 (6F in Hexidecimal - In FSC File Name, e.g xxxxxxx_006F0001.fsc)
Base Variant = HU_CIC (CIC module name, e.g. HU_CIC, HU_NBT, etc.)
Upgrade Index = 1 (In FSC File Name, e.g xxxxxxx_006F0001.fsc))
Select "Upgrade FSC" to Import and Activate FSC Code.
Select "Check FSC Status", and you should see:
AppID 111
UpgradeIndex 1
SWTType SWTclassic full
FSCStatus accepted
FSCCertStatus accepted
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 10-31-2013, 07:08 PM
izen izen is offline
Mein Auto: F34
Smile
AppID 111
UpgradeIndex 1
FSCStatus accepted
My 216 FSC has arrived in the form of 3 files of xxxxxxx_00830001.xxx.
Its AppID is deduced as HEX 83 (DEC 131).
. is Base Variant EPS? Diagnostic address?
. upgrade index will be "1". since there is no prior 216 FSC in the car before, for this initial importation, do I still use "Upgrade FSC" instead of "Write FSC" or "Update FSC"?
. when do we use "Write FSC" , "Update FSC"
. when do we use the .xml file?
thanks in advance!
Old 10-31-2013, 07:19 PM
thanks in advance!
With EPS, I do not know if it is Imported and Activated in CIC or EPS Module, as my car does not require FSC Code for it.
Just use "Upgrade FSC" as I wrote.
The .xml version is not used with E-Sys, rather it is used for Importing and Activating with ISTA/P.
Old 10-31-2013, 08:15 PM
TokenMaster's Avatar
TokenMaster TokenMaster is offline
Token Master
Mein Auto: Coded F30
I'm not sure why E-Sys just don't use the XML file though, as it contains both the FSC and the certificate
Code My Bimmer| FDL Coding Video Guide -Blogger/Youtube | EST Software Token demo | E-Sys Launcher Premium and PRO
Never download already patched E-Sys from Torrent sites
Old 11-01-2013, 04:07 AM
True, but that's just how it is. It can only process the .fsc file Base 64 Decoded.
Old 11-01-2013, 05:51 AM
Mein Auto: F34
glad to report the 216 fsc import and activation was just done.
added VO 216 first and then fsc check, DME[?] and EPS showed up missing FSC along with retrofit HU_NBT.
after fsc upgrade, in EPS, FSCStatus accepted, but FSCCertStatus unknown.
started engine, the steering became very light at low speed. that should be the feel of servotronic. [my previous car was e46, guess no servotronic with it so i can't really tell the difference.]
rechecked fsc, EPS gone, leaving only retrofit HU_NBT there.
Thanks Shawn and others here for the help. This has essentially saved me eur 200 activation fee as the local dealer insists only to sell the fsc code to me with the bundled activation service.
The local dealer was still telling me yesterday they were negotiating with Munich, trying to bend the rule for me after I protested. While frustrated, I just decided to buy the code from another dealer from Germany and it arrived today.
Old 11-01-2013, 07:20 AM
Glad it worked for you.
Old 11-25-2013, 10:22 AM
Seaisfreedom Seaisfreedom is offline
Mein Auto: BMW 118d Urban
What is the fsc code?
Old 11-25-2013, 10:36 AM
FSC Code for what? I don't understand your question.
Old 11-25-2013, 10:51 AM
are there many fsc code? for example if i'd like add 6NK or another option in FA......do i need the FSC code?
Old 11-25-2013, 10:53 AM
Yes, there are many FSC Codes, but Bluetooth does not have one, so you do not have to worry about it.
Old 11-25-2013, 10:54 AM
how many FSC code? thanks i'd like study about coding
Old 11-25-2013, 10:57 AM
Way too many to list, but the primary ones you are most likely to encounter are Navigation Application, Navigation Enabler, Navigation Map, Voice Control, Satellite Radio, BMW Apps, Speed Limit Information, and Night Vision.
We discussed the BMW Apps one already...
Old 11-25-2013, 11:02 AM
mmm....navigation map and BMW Apps are important for me. what are speed limit information and night vision?
Old 11-25-2013, 11:06 AM
Vehicle Options:
S611A BMW Night Vision
S8THA SPEED LIMIT INFO
You can read about them on BMW's website.
Old 11-25-2013, 11:47 AM
to activate active beam what i need?
Old 11-25-2013, 11:51 AM
What "beam"?
Old 11-25-2013, 12:01 PM
when the xeno light turn with the car
Old 11-25-2013, 12:03 PM
excuse me, i wrong......BMW Adaptive Light
Old 11-25-2013, 12:05 PM
S524A Adaptive Headlights requires no FSC Code. So, add the AHL Hardware and code the car if you want.
Old 11-25-2013, 12:08 PM
many thanks for your support.....it's very important for me. write you later for another option. thanks
Old 11-25-2013, 12:14 PM
in new price guide of bmw f20 there is write new option 6NS and there isn't 6NK. do you know it?
Old 12-16-2013, 05:47 AM
economi$t economi$t is offline
Mein Auto: BMW X5
who knows how to activate the Navi cic to e series with fsc code files without ista
Old 12-18-2013, 06:45 AM
vince59's Avatar
vince59 vince59 is offline
Mein Auto: ducati
Shawn, I found different parameters settings for esys when extracting the "file" for FSC and I am a little bit confused. Can you please confirm the following are the correct ones for the HU_NBT in a f25 coded with data 50.4?
diagnostic address: 63 (0x63)
application number: DE (0xDE)
base variant: HU_NBT
upgrade index: 1 (0x01)
