The X5 SAV Forum
Old 03-07-2013, 12:12 PM
uberbestest uberbestest is offline
Mein Auto: 01 x5
01 x5 rear fuse box diagram
Was having an issue with suspension draining battery life in the winter, may have been over zealous and ripped out most of the fuses in anger. Was wondering if someone could throw up a pic of the diagram that is on the rear panel so I could reinstall the fuses properly.
Any help is appreciated thank you!
Old 03-07-2013, 02:04 PM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
See if this is any help:
http://www.xoutpost.com/bmw-sav-foru...x-diagram.html
Old 03-08-2013, 11:51 AM
Mein Auto: 01 x5
I saw this a few days ago and was actually planning on trying that set up if I could not find a 2001 diagram.
Old 03-13-2013, 11:55 AM
trfraser trfraser is offline
Mein Auto: 2001 x5 4.4i
you might have a leak in the rear air suspension , as it gets low it airs back up even when the car is not running , the compressor turning off and on can eventually run down the battery . Pull the green 30a fuse (closest to the tailgate)( the first green fuse )in the back fuse box, that will stop the air pump from running while not being occupied . If there is a leak the car will be low in the back when you are ready to drive it. Just reinstall the fuse and it will air back up to normal levels...
