Old 02-05-2013, 08:01 PM
Kevin Halbleib Kevin Halbleib is offline
Mein Auto: 740il
1995 740IL Radio will not come on.
I just bought a 1995 740IL.
Immediately I notice that the Radio Cluster will not power on at all. None of the buttons on the steering wheel will work other than the horn.
I did test the battery. All Good.
I purchased a NEW ignition switch. NO Change.
I am not sure where to go with this.
Any help??
Old 02-06-2013, 06:52 AM
BMWFatherFigure's Avatar
Old School
Start by checking the plugs/joints/earths in the dash. Then the same with the modules in the boot.
Current:
E38 Parts Car
Previous:
Old 02-06-2013, 06:54 AM
Mein Auto: 740il
I am not sure what you or should I say mean by plugs/joints/earths in the dash? Do you mean I have to remove the dash or radio?
What is the boot?
Old 02-06-2013, 09:54 AM
keith718 keith718 is offline
kmabike
Mein Auto: 2k 740iL. Orient Blue
Your ignition switch might be bad. A lot of quirky things go wrong when an ignition switch goes bad. I had this problem and the first thing that went wrong was my radio.
Old 02-06-2013, 05:36 PM
Mein Auto: 740il
Yes. I did replace the Ignition Switch already. No Change.
Old 02-06-2013, 06:04 PM
Old School
For ''boot read 'trunk'. You wont have to remove the dash but you will have to get access to plugs etc to get them clean and electrically sound. Same with the earth (ground) points. Check for water getting into the fuse box under the bonnet too.
Current:
E38 Parts Car
Previous:
Old 02-06-2013, 06:27 PM
Mein Auto: 740il
I have to ask, what do you mean under the bonnet??
Old 02-06-2013, 06:54 PM
Old School
Hood
Current:
E38 Parts Car
Previous:
Old 02-06-2013, 07:06 PM
Mein Auto: 740il
That's what I thought you meant...
Kevin
Old 02-06-2013, 08:13 PM
Mein Auto: 740il
wires??
I looked in the area where the cd changer is, I see these wires dangling. Could this be the problem?? I do not see where they could plug in though.
Old 02-07-2013, 02:46 AM
slimbaby slimbaby is offline
Mein Auto: BMW 650I
Hi Kevin, I am pretty sure those wires are for extra accessories that did't come with the vehicle. It's normal for bmw to have these wire harnesses for future add-ons. Before you spend to much time and money on this problem check all your fuses. Sounds like you might have blown one.
Old 02-07-2013, 04:11 PM
Mein Auto: 740il
Only fuses I see is one under the hood. It is good. and one in the trunk where the battery is. Is there any others?
HTML code is Off
