Old 02-05-2013, 10:29 PM
othman.almulla othman.almulla is offline
Mein Auto: 2006 650i
Broken molding and speaker issue.
Hey guys, I was wondering if someone could help me figure out what the best solution would be for two issues. A) My rear passenger speaker is really scratchy and distorted. What is the easiest way to fix that. B) I bought my car used and it looks like the molding in the pic where it says here is broken or missing something,its also broken on the other side. Maybe a light? or is it just an aesthetic piece?
Old 02-06-2013, 01:06 AM
Yorgi's Avatar
Yorgi Yorgi is offline
The distortion is probably the amp. It's located in the trunk on the driver side behind the carpet.
Those holes are mounting points for the windscreen. The trim pieces are missing. See part #12 in this diagram.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 02-06-2013, 02:40 AM
Thanks a lot Yorgi!
Old 02-06-2013, 08:06 AM
tampamark tampamark is offline
Mein Auto: 650 Sold - '12 Jaguar XK
The top speaker is missing it's cover? They should both have a grill.
Does the speaker without the front grill have holes in it? I can't tell from the picture whether it is bad lighting or if your cone is torn up. If it has holes then you definitely have a bad speaker!!!
