Old 02-05-2013, 10:45 PM
Utemachine Utemachine is offline
Mein Auto: 09 535 xi
Slight lunge on start up.
I have an 09 535xi with about 64k miles on it. About a month ago it started to lunge or jerk forward a little bit as soon as I press the go button. I've read a couple places this is a programming issue. Does anyone know what's going on?
Old 02-09-2013, 06:25 PM
Nobod has had this issue? On start up the car jerks forward a little. Any help would be appreciated.
Old 02-09-2013, 11:02 PM
2chill's Avatar
2chill 2chill is offline
Mein Auto: 2008 528XI
My car did that also, usually when it was cold. It's the programming on the transmission. There's a service bulletin on it. Just take it to BMW and explain what it is doing and they will reprogram the transmission. If the car is under warranty they will do it for free. I don't know what the charge is if out of warranty.
PP, CWP, NAV, satelite radio, USB, Folding Rear Seats.
Old 03-15-2013, 09:23 PM
Thanks 2chill!
Old 03-16-2013, 11:18 AM
2chill's Avatar
Did you have the problem corrected?
Old 03-24-2013, 07:41 AM
So I'm a little frustrated. I took it into a bmw specialist and he found a service bulletin similar to my problem but then said my software is up to date. So I still have the problem. He threw it up on the rack to check if everything was tight and it is. He said for him to go further it would be 110 per hour for trouble shooting. I figure I would do some trouble shooting on the Internet. Any advice what to do next?
Old 03-24-2013, 10:02 PM
2chill's Avatar
If you don't want to pay BMW trouble shooting prices, find a good BMW Indy. Have him check the mechatronics sleeve which may be leaking. It's possible you may be slightly low on fluid. The pressure in the tranny is dropping when your car is at idle, then when you hit the gas, the sudden build up of pressure is causing the car to lunge.
My car had a leaking mecha sleeve which caused low fluid and the rpms to rev high then go back down on the highway. BMW fixed it under the CPO warranty.
