E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
Z4 run flat tires
I bought a 2004 with 19,000 miles that has the original run flats on it. The tread is OK but they are pushing 10 years old, so I am planning to put on new tires. I am new to run flats and have read a zillion threads, which are often conflicting. I don't even understand the concept behind run flats, except that they are an excuse for leaving a spare and jack out of the car. As an engineer, I can't get my mind around a tire that:
1. allows you to drive 50 miles to somewhere when you get a flat. 2.once you get there the tire can not be repaired and must be replaced 3. when you get there, no one is likely to have a replacement or the equiptment to install run flats 4.If the tires have more than slight wear, they should be replaced as a full set? 5. some owners claim that run flats are more likely to get flats than conventional tires? Am I missing something here? Thanks in advance for explaing the logic to me. PS If you put a spare and jack or a slime repair kit in the trunk, how do you tie it down so it doesn't fly around. Is your AAA card a better solution? |
I swapped mine nearly immediately after buying my car for a $400 set of Sumitomos from Tirerack. Should I blow one - that's what my insurance policy roadside assistance is for. I honestly don't see many benefits from runflats, in case of severe damage they will explode like any other tire, while replacing or otherwise purchasing them is at least twice the cost of regular rubber.
What you really miss without runflats is a harsher ride and mediocre handling. Get a set of good, non-runflats and you will be amazed at the ride difference, plus they are less expensive.
I had run flats.
Tramlining. Harsh Ride. Expensive to replace. Wife did not like to drive the car. I got go flats. Tracks straight. Smooth. Quiet. All of a sudden, my town had great roads to ride on. My wife loves to drive the Bimmer now. I miss the run flats. Not. |
Glad to see this thread... I have run flats and can't stand the ride. My other car has always had Bridgestone Potenza Pole Position tires... fantastic tires and I'm pretty sure that I'm going to swap these out.
Not to push Sumis, but I'll be honest with you all - for the measly price Tirerack charges for them, Sumitomo are incredible. Quiet, great grip, take highway ramps at 65mph without a squeal. Had Potenza run-flats fresh out of the dealership - thought my front wheel bearings were shot.
Keep in mind: Front and Rear sizes are different, at least for the 17" sport package wheels. |
1. Very stiff and thick sidewall to support the tread off the rim without air.
2. Because the sidewall folds and to the two parts rub against each other, it damages the sidewalls, thus they need to be replaced. 3. Oh well. ![]() 4. This is always a good idea. As a tire ages and wears, the traction characteristics change. And in doing so, you can change the vehicle dynamics to cause issues when you need the performance. 5. No idea. BTW a number of BMWs and other cars did/do not have spares, even without run flats. Our M Roadster, E46 M3, and Fiat Abarth all are spareless, without run flats.
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
06-08 - M Roadsters and Coupes came with regular tires and a fix a flat kit and air compressor. I had a 04 prior to this M and I stayed with Run Flats but went with a softer tire. Bridgestone vs Kumho. Kumho's were less expensive and had a better ride. You will never get the ride of a regular tire with a run flat. They have come a long way since their creation and I am sure that they will get better still. But if given the choice between a run flat vs regular, give me regular any day. It just boils down to your risk factor.
You are correct, there are thousands of threads comparing RFT vs Regular and you won't get but two answers, go or no go. Best of luck.
2008 Z4M Roadster BMWCCA/ZSCCA Member |
![]() Sent from my Galaxy Nexus using Bimmer App
FS: 6 CD Changer http://www.bimmerfest.com/forums/sho...d.php?t=335200 PM or email to screen name at gmail |
So the only problem with go flats is that my wife will want to drive the car?
Aaa card is a better bet, A+ gives you up to 100 mile tow, I got some conti for about $80 a piece, car runs great, run flats and expensive high performance are all over rated, unless you are driving on a race track, get some affordable tires, you will be fine
Z4 run flat tires
Tried to get regular tires on run flat rims. Shops here would not install because they said make up of rim specialized to run flat tires. They say that tire might seperate from rim at high speed. Bought new rims and Bridgestone's 760 RE sports.
Sent from BimmerApp mobile app |
![]() I'd love to hear how they think non-run flats would separate!! I just replaced my tires with RFT, but I made the choice to do that...no a tire shop.
2006 BMW Z4 3.0i Black/Tan/Black |
As I understand it, there are two run flat systems out there. One type has a supporting rib in the center of the wheel to support the tread in the case of a flat. These wheels are most definately different than conventional wheels. The more common type (used on BMW) has thick, stiff sidewalls on the tires which can support the tread in the event of a flat. The wheels for this type are also different, but I am not sure how. I suspect that the wheel bead is stronger/deeper/ heavier, but I am not sure which. What I do know is that there is no problem putting non run flats on this type of wheel, but not all tire changing equiptment can handle run flat wheels. I recently switched to non run flats and had to check around to see which shops had the right equiptment to remove the old run flats from my wheels, and some did not. I will say that in all the bazillion posts about run flats on this and other forums, this is the first time I have ever heard of someone putting run flats on a car that originally had conventional tires. I sure hope you car has a tire pressure monitoring system, because diving on run flats that have less than 15 psi in them results in a non repairable tire.
Z4 run flat tires
Best thing I ever did was to ditch the run flats for Conti Extremes.
I put Hankook V12s on my OEM wheels, no problems
the stable: 2003 BMW Z4 3.0i 2008 Hummer H3 Alpha 2008 Suzuki SX4 |
I fitted 4 Goodyear F1 Asymmetric 2 non-runflats on my factory Z4 108-style wheels last summer and never looked back. It's a great improvement, as Teacher Blind discusses above. Anyone that tells you need special wheels in order to install non-RFTs is full of equine dung.
Ditched the runflats
I got rid of the Bridgestone runflats and bought a set of Coopers for my '07 3.0si. Have been amazed at the difference in the ride, handling, quiet, etc. Put a scissors jack, plugger, and small compressor in trunk just in case. Can't remember the last time I ever had to actually change a flat on one of my cars.
I've been driving my Z3 without spare or run flats for going on six years. The spare which sits in my garage is virtually useless. Get a mobility kit if it makes you feel more secure.
SS braces, AST 4200's coilovers, Vorshlag camber plates, GC RSM, H&R Front sway, Conforti CAI, Magnaflow exhaust, Recaro seats, and Apex ARC-8 with RS3's and Style 32's with Pilot SS for autocross |
You know, I think I can call for roadside assistance with 1) BMW or 2) my insurance company. Either way, I would be covered, I would think. Given that our tends to not go too too far (not yet, anyway) I can't find a good excuse to keep the run flats.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
