Old 07-13-2015, 08:14 PM
bananawing bananawing is offline
Mein Auto: 2003 Z4
Where is the headlight sensor?
Where is the headlight sensor? I want to stick a piece of tape over it so my headlights are automatically on full time, day and night.
Old 07-13-2015, 09:10 PM
enzed4's Avatar
enzed4 enzed4 is offline
Mein Auto: E85 2008 2.5_Si
Is this a trick question? Just turn the headlight switch from 'auto' (far left position) to 'on' (far right position)
Unless I misunderstand your question?
Old 07-14-2015, 05:13 AM
kalali kalali is offline
Mein Auto: 2003 Z4 2.5
Why waste all that energy twisting the knob when it can be done automatically....
Old 07-14-2015, 08:15 AM
Mein Auto: 2003 Z4
It is not a trick question. I just want headlights on whenever the car is running. I have CRS and forget to turn them on and off. My GoldWing and Dodge Diesel have lights blazing all the time, it helps other drivers to see you.
Old 07-14-2015, 01:14 PM
enzed4's Avatar
I guess if you leave the headlight switch in the 'on' position, they will be on when the key is in the 'accessories' position? So you would run the risk of flattening the battery if you were parked up listening to the radio, for example. Or do the headlights not come on unless the ignition is at the position after accessories? I've never actually checked...
My guess is that the ambient light sensor is in the same place as the rain sensor on the windscreen up by the rear view mirror? Shouldn't be hard to block off that area and see if the headlights come on.
Old 07-14-2015, 02:17 PM
bwitherel's Avatar
bwitherel bwitherel is offline
Mein Auto: 2006 Z4 3.0si
The headlight sensor is up in the center of the window near rain sensor. You can see the eye if you look closely
Old 07-14-2015, 02:19 PM
bwitherel's Avatar
If it is that important to you I guess you could remove the plastic rear view mirror cover and stick a black piece of paper over the eye.
Old 07-14-2015, 03:35 PM
u3b3rg33k u3b3rg33k is offline
Mein Auto: e30, e60, R1100S
Do the Z4's not have angel eyes? those are more noticeable during the day than low beams anyways.
e30: '87 325i: MAF+WAR chip, long tube STAHL headers, 5MT swap, 4.27 torsen
e60: '08 550i M-sport, 6MT, ARC, Active Steering, 19" wheel delete
R1100S - oilhead FTW
Originally Posted by MeNoo View Post
Although I have nothing scientific to say, I can confidently say that it works.
Originally Posted by Burning2nd View Post
If you want to use the fuhrers snowmobile you gotta have das tires
Old 07-14-2015, 04:49 PM
bwitherel's Avatar
Mine has the angel eyes -- I think 2006 on have it.
