Old 02-06-2013, 12:08 PM
cokewithvanilla cokewithvanilla is offline
Mein Auto: 2007 BMW 328i
Quick question about VANOS
Hello,
I live in an apartment and I am heading to my parents (4 hour drive) to do some maintenance on Friday. I have been wanting to clean the VANOS for a long time. I don't think I will be able to get any seals or parts by then, do you think I can take them off without needing to replace the gaskets? Also, Does anyone have detail on the procedure on hooking them up to a power source (like how many amps, I think its 6v, and which is positive/negative)?
On a side note, I will be changing the transmission fluid, diff fluid, coolant. Anything else I could add to the list for 100k maint.?
Old 02-06-2013, 01:17 PM
fun2drive's Avatar
BMWCCA 149159
Brake bleeding unless yours is OK in that regard. VANOS removal should not damage both the seals that are in there per VANOS. I would order new seals regardless because if they leak you have the parts and if not you have them for the next cleaning and they are dirt cheap maybe 8 bucks a set or so.
If your VANOS is working why would you need to check the operation? If it isn't working then swap the VANOS around as they are interchangeable.
I doubt they are 6 VDC I would expect them to be 12 VDC. How do you know what is what? Use a VOM and just check the plug that will provide you the input however I think the operation is normally off until you get to a certain rpm when the DME will send a signal to provide power to the solenoids. I am not certain on this but on other older VANOS that is how they operate.
Here is a video that shows how to do this on a 4 cylinder. Your engine being a 6 cylinder is virtually the same and you should be able to follow this as a guide.
Not that the VANOS comes out the front of the engine and not toward the rear it is much easier to do unless there is some clearance issue like the radiator...
Here is the realoem.com site for part numbers
http://www.realoem.com/bmw/showparts...36&hg=11&fg=15
Old 02-06-2013, 02:33 PM
Thanks for the reply. I do hope to get the seals eventually. I wonder if a BMW dealer stocks them. Time to make some calls. I threw the VANOS codes a while ago, did an oil change and they went away... I figure they are probably dirty after 100k miles.... never hurts to clean them, right? I read somewhere that they were 6 volts... someone said specifically not to run 12 to them
Originally Posted by burgess.1@tisca View Post
4. Rigged up an independent power supply of a variable 5.5 volts (do not apply 12volts)
Actually 5.5, i guess.
My brakes seem very good. It looks like some fluid has leaked out of the master cylinder at some point.... there is crusty fluid around the fill point. Don't know if this is an issue.
Old 02-06-2013, 04:24 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
perfect
I will do myself now
dealer here charge $1000+ to replace...
what a scam
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 02-07-2013, 08:24 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
Just for clarification, you are talking about the VANOS solenoids, not the VANOS itself. And I would disagree with you on the "never hurts to clean them" statement. If the codes went away after the oil change, your problem is fixed. The cleaning additives in the new oil did their job. Cleaning is recommended if you have a problem. It is definitely not recommended if there isn't. Can see absolutely no upside.
Old 02-07-2013, 11:16 AM
Yes, sorry. I meant the VANOS solenoids. Just curious, but what could go wrong in cleaning them?
My theory, and I am basing this on no facts at all, is that they were probably gunked up, new oil helped, but didn't necessarily remove the gunk. I feel like the codes will come back with time. The car was not due for an oil change for many, many miles. I did it on a whim after reading a forum post.
