Throwout bearing just went out. How difficult is it to replace? - Page 2 - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 02-08-2013, 01:46 PM
CJ74753 CJ74753 is offline
Location: High Point / Thomasville area of North Carolina
Mein Auto: 91 BMW 525i
Well what happens if you don't mark the driveshaft before you pull it out? I thought I got chalk marks on all the pieces but I obviously missed where the front of the driveshaft connects to the tranny, got it marked on the back of shaft and diff...
Old 02-08-2013, 02:55 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
You may be okay here. If you have not turned the output shaft of the transmission, then you can place the driveshaft back at the differential and line up the marks (you may need to run a bolt or two through to hold it), then you should be able to hold up the end that connects to the transmission and mark it.
Otherwise you risk it being slighlty off balance, but I don't think it would give any noticeable vibration, but can't say for sure.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 02-08-2013, 03:00 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
I think that it being off balance would almost certainly make it vibrate... or shudder, no?
Sent from Joe's Galaxy Tab 2 via BimmerApp
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 02-08-2013, 03:10 PM
BMR_LVR's Avatar
Humble E34 lover
I guess it depends on how much it is off balance. If only very slightly, then it shouldn't shudder much ... or hopefully so. Otherwise, you would have to bolt it up, see how it drives and, if it shdders, unbolt it, rotate it one bolt and drive it again until the shudder went away and repeat as necessary until it has been rotated to the correct spot
Unless there's some other way that I don't know about (which is entirely possibe).
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 02-08-2013, 05:42 PM
Otherwise you risk it being slightly off balance, but I don't think it would give any noticeable vibration, but can't say for sure.
Well it got moved so that's out...and for the record I HATE that shifting arm pin that connects it to the transmission.
Old 02-09-2013, 02:52 AM
_Ethrty-Andy_'s Avatar
E30 Mad
Mein Auto: BMW
You WILL notice it, and it will prematurely wear out your centre hanger bearing as well, not the bearing itself but the rubber will tear. I do not know for sure but logically it should damage the output bearing in the transmission and/or input of the differential.
a few teeth out MAY be okay, but any more than a 60 degree turn and its not going to be any good. but you should be able to get it balanced at a transmission shop or engineering outfit etc for a box of beers, so all is not lost yet.
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 02-09-2013, 06:54 AM
cutter67 cutter67 is offline
Mein Auto: 530,m6,633
Wow i better get a fsm on 530 because i always thought the driveshafts were indepedently balanced and all you had to worry about was the yokes lined up right if you rebuild them. So they are balanced on the car complete
Old 02-09-2013, 02:51 PM
E30 Mad
Mein Auto: BMW
correct.
E30 above Sold
Old 02-09-2013, 03:48 PM
You will most likely really hate the bellhousing bolts
..........I'm having a blast with these. I got 5 out...these things take a lot of torque to remove
Old 02-09-2013, 04:47 PM
BMR_LVR's Avatar
Humble E34 lover
My thinking in the first quote was if OP had not separated the two sections of the driveshaft. I agree who heartedly that, if he did separate them and didn't index the sections, then he will need to have the driveshaft re-balanced.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 02-10-2013, 08:39 AM
The drive shaft is still together, I just didn't mark where it connected on the yolk ( I guess thats the term for that y looking piece on the rear of the transmission. I just have to get those last 2 torx bolts out the top of that transmission now. So I still need to go get it balanced correct? Was trying to figure out if I should replace the center bushing while its off...I'm trying to do maintenance but also get the car back on the road for the wife. Will post some pictures of it in a while.
Old 02-10-2013, 02:45 PM
Question
Does anyone have a picture reference as to the bolt removal on removing the transmission? I thought I got all of them out, counted 10 so far 9 on back side and 1 small one on the front, Bentley book shows 11 but the transmission is not pulling away easily like it says it should.
Old 02-10-2013, 02:51 PM
Monsignor's Avatar
Mein Auto: Sig
Via Pelican Parts Tech Article
Sent from Joe's Galaxy SIII via BimmerApp
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 02-10-2013, 03:18 PM
You see that little small picture in the bottom corner? Well it appears that the smaller bolt of the two on mine is missing/broke off in there. I can see the bolt in there. It looks like someone used a grinder or something near it. What in the world...
Old 02-10-2013, 03:31 PM
Monsignor's Avatar
Mein Auto: Sig
Why do you only have one of those two? And it doesnt seem threaded, it should just pull off of it. Then you can replace it once the tranny is off. And those two arent a part of the larger picture's 11 I believe. So you still may be missing some...
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 02-10-2013, 03:43 PM
thats a drift pin i think you will find out. these help guide the transmission. if is a broken bolt dont worry about it the tranny will still come of. if you are sure you have gotten all the bolts, sometimes the tranny hangs up on the pins or the pilot bearing. (it just doesnt slide out easy all the time).
as far as the driveshaft goes i have removed hundreds and never marked them. someone will have to explain how replacing a rotating object on a fixed axis changes the balance if rotated to a different location. but i can be stupid. i wonder how tires are balanced and put back on.
need pictures please and it sounds like things are going good
Old 02-10-2013, 03:56 PM
south26 south26 is offline
Mein Auto: 535i 1989
The tranny weighs about 85lbs. It is not to bad to take out, I have done it by myself with a regular floor jack. I just put a board on it and slowly lower the tranny. It is much easier then the auto tranny that weighs 142lbs after being drained(that is with out the converter)
You might think about going to a single mass flywheel. You can use a m20 one from either a 528e or a 325i/e. It is lighter. You do also have to replace the starter for a m20 starter. But you can get the fly wheel for 60 to 70 dollars and the starter from 35 to 55.
Andy
Old 02-10-2013, 05:05 PM
Here are some pictures...you can tell my transmission bushings were shot, my cats holding the car down so it don't move, these are all of the bolts I pulled off the transmission and it still seems locked down...as you can see I got it to move a little but its not wanting to come off. My slave cylinder leaked some fluid when I removed it, is that normal if the plunger gets moved? Was a tight fit to remove it. Kinda messed up the head of 1 bolt, my breaker bar let it slip off.
EDIT: I don't think I removed enough of the transmission mount to pull it off now that I look at it
ID:	361722   Click image for larger version
ID:	361723   Click image for larger version
ID:	361724   Click image for larger version
ID:	361725   Click image for larger version
Old 02-10-2013, 05:19 PM
i only see one bolt with a nut i think there should be two one on both sides of bellhousing right across from each other. are you using a torx socket or a 12 point socket if you are using a 12 point socket dont buy a set of torx sockets. if the transmission is not moving there still has to be a bolt somewhere if one side is moving check other. when all else fails get out from under the car and pet the cat holding the car down take some deep breaths and clear your mind and then dive back under there and find the bolt..repeat as needed. dont let this piece of metal out think you
edit: the slave cylinder will seep a little and in colects in the boot when you pulled it away it freed the passage for it to leave the boot. replacement is a judgement call. it might last another 100k or it could fail pulling out on the test ride...the question is do you feel lucky
Old 02-10-2013, 05:30 PM
Yeah I dropped the 2nd nut on the engine side while removing it. Yeah I got a set of torx for the job e10 and e14 are the sizes should anyone care. It appears stuck together at the top by that drift pin as you called it.
Old 02-10-2013, 05:56 PM
I would check again for a bolt up there 90% of the time thats where they are missed
Old 02-10-2013, 06:40 PM
I'm 99.999% sure there are no more bolts up there, I bear hugged the transmission and felt all empty holes...is there anything that could bind it up and not let it loose? I can see it wiggle as I yank on it...I am stumped here
Old 02-10-2013, 06:44 PM
Have you tried a prybar between the engine and bellhousing yet
Old 02-10-2013, 06:54 PM
I have been slowly prying around it with a long flat head and have got it spaced apart some...guess I might just need to keep working it apart
Old 02-10-2013, 07:05 PM
If its coming even then its stuck on the alignment pins. Just keep doing it from side to side
