E34 (1989 - 1995)
Old 02-18-2013, 04:36 PM
CJ74753 CJ74753 is offline
Location: High Point / Thomasville area of North Carolina
Mein Auto: 91 BMW 525i
Well I got hold of the builder and he got a plumber out here, both plumbers said they had never seen one of the pex brass clamp rings break. Well back to business...Okay how in the name of God does this driveshaft come apart? I took it to a machine shop and he worked on it for about 5 minutes and he gave it back to me and told me he had no idea how to get it apart?
Old 02-19-2013, 04:43 AM
cutter67 cutter67 is offline
Mein Auto: 530,m6,633
there should be a 19mm bolt holding the york in place. now this is where you want to put marks on both sides so you put the halves back together the same way.
see the bolt head behind the yoke
EDIT sorry i missed the part where you removed the bolt. the shaft comes apart there for sure tri some BP blaster you may have to press it off and that means you have to take the universal joint apart
Old 02-19-2013, 07:07 AM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
Originally Posted by _Ethrty-Andy_ View Post
people are saying to change the clutch and pressure plate and resurfacing the flywheel because of where you are. its a time consuming procedure to drop the transmission, so it makes sence to replace the clutch and pressure plate while you are in there.
Theoretically, the throwout bearing should have been replaced the last time it had a clutch change, so it failing could be a sign that it is on its way out. or prehaps the last person to service it didnt change the bearing.
Could also means that the person like to ride the clutch while he is waiting at a light.
Old 02-19-2013, 07:09 AM
Originally Posted by CJ74753 View Post
FINALLY....that guide pin was stuck, wiggled a flat head around it popped loose. What happened to 2 of my clutch fingers...
Looks like they broke off.
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
Funny story. My dad picked up a jetta TDI 6-spd last week. we we're driving around and he's sitting at a red light, clutch on ground, car in gear. Car has 94 miles on it.. had to give him a talking to after that
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 02-19-2013, 05:07 PM
I don't like the sound of that..it don't even look like they come apart. Appears they are put in there and then the metal is stamped with little indents. My rubber o-rings or seals on the u-joint some of them are broke/deteriorated and fell off. How much am I looking at to get this dang thing fixed...can't seem to catch a break.
Old 02-20-2013, 05:13 PM
Is it just my Bentley book or am I overlooking it I can't find anything talking about the flywheel and bolt torque specs. Well my drive shaft is at the shop..hopefully he can get the blasted thing apart. Bentley book is wrong also well at least on my car...it says you need a 30mm thin walled deep socket to remove the but to get to the transmission output seal, it's a 36mm.
Old 02-20-2013, 06:30 PM
TWard's Avatar
TWard TWard is offline
Mein Auto: 91 e34 525i
Whaaaa? never heard that one before
Old 02-21-2013, 06:02 AM
Monsignor's Avatar
Mein Auto: Sig
really? Maybe i worded it poorly...
He'll be waiting at a red light stopped, in first gear with the clutch depressed the entire time. Very unhealthy habit for the car. Its so he can just let the clutch out when it goes green. we're veering OT now though...
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 02-21-2013, 06:38 AM
Question
Can anyone tell me the fly wheel bolt torque specs and show me where in the Bentley it gives that info?
Old 02-21-2013, 07:40 AM
Monsignor's Avatar
Mein Auto: Sig
77lb-ft on the Flywheel.
18lb-ft pressure plate to flywheel
r3vlimited thread
BMW-M Torque Specs.pdf
Sometimes you need more than bentley, my friend.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 02-21-2013, 04:56 PM
Is it horribly bad that I forgot to lubricate the transmission output seal? I can't remember if it was this hard to turn before. Perhaps it just needs broke in...
Old 02-21-2013, 07:58 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
it will require quite a bit of effort to turn
but as far as having to lubricate it or not, thats beyond my knowledge, i havent done rebuilds of engines trans diffs etc yet
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 02-22-2013, 02:50 AM
it will be hard to turn just just put a little oil around the seal you should be fine
Old 02-22-2013, 08:03 AM
Not sure I can get any oil on there now with the flange on. Just hoping this isn't going to ruin the seal or cause a leak..perpaps some Liquid Wrench Dry Lubricant will work. About to bolt transmission back up, whats it mean about preloading the driveshaft?
Old 02-22-2013, 08:12 AM
preloading the driveshaft is pushing the center bearing as far forward as possible and then tighten it down if you look there are slots on it
as far as the oil goes pour some down the splines it will makes way to the seal dis you replace rear seal also
Old 02-22-2013, 11:11 AM
Yeah, I replaced all the seals. Well if it starts leaking due to bad new seals I'll know where I went wrong and I'll be pulling the transmission back out..because the transmission is bolted back up partialy..lots of pics coming soon. Just got driveshaft back from the shop.
Old 02-22-2013, 02:10 PM
Well I just hit yet another problem..I can't remove the driveshaft centering sleeve that is pressed into front of driveshaft. Its damaged and won't even budge using grease and socket trying to force it out. Ideas?
Old 02-22-2013, 02:12 PM
if we are thinking about the same thing, it doesnt come out. you need to put that end in first before doing up the centre hanger bearing
E30 above Sold
Old 02-22-2013, 02:15 PM
Oh it has to come out...its #1 here http://realoem.com/bmw/showparts.do?...06&hg=26&fg=10 I bought a new one from the dealer cause someone dinged the sleeve so bad it wouldn't slide back on transmission.
Old 02-22-2013, 02:25 PM
Monsignor's Avatar
Mein Auto: Sig
how do they suggest you remove and install it? can you post a picture? doesnt seem to be any sort of way...?
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 02-22-2013, 02:40 PM
Read another post on the board here and they forced it out by packing grease in it. As soon as the wife gets back with my truck I'll take a picture of the new one. Slide hammer might be able to grab it..
Old 02-22-2013, 02:42 PM
Monsignor's Avatar
Mein Auto: Sig
woof. do let us know if and how you get that out. would be very interesting
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 02-22-2013, 02:46 PM
i have never heard of anyone removing that.
E30 above Sold
Old 02-22-2013, 02:51 PM
Here's the new one
ID:	363412   Click image for larger version
