E34 (1989 - 1995)
Old 02-22-2013, 03:04 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
^ im not calling you out, i do believe you, i just havent heard of anyone having to replace it before
Old 02-22-2013, 03:46 PM
CJ74753 CJ74753 is offline
Mein Auto: 91 BMW 525i
Haha success...I love Autozones blind hole puller
ID:	363420   Click image for larger version
Old 02-22-2013, 04:43 PM
Flex disc bolt torque is supposed to be what? All my bolts all have 8.8 stamped on them, parts look up says there's supposedly 2 sets of 3 and they've different part numbers. Looks like 34ft/lbs for 8.8 bolts if Bentley is right...got confused caused the part list said they are m12 just confused lol
Old 02-23-2013, 02:06 PM
Exclamation Shaking...
Well this isn't any good...I put the car back together and it has a horrible shake starting at about 30mph and gets worse from there...I guess the driveshaft is wobbling. What do I do now?
Old 02-23-2013, 02:42 PM
did you do the centre hanger bearing up?
Old 02-23-2013, 08:31 PM
Question
Yeah, I put the shaft on the final drive and bolted it up, placed bolts and nuts through front shaft to flange, preloaded bearing (pushed shaft towards transmission as far as I could and tightened center bearing. I don't know if I messed up our what. I didn't mark the drive shaft flange to transmission flange/flex disc before I pulled that apart. I don't see how that could cause that though...
Old 02-25-2013, 05:49 PM
Any ideas?
Old 02-25-2013, 06:41 PM
you did put the rubber donut back in too right?
Also, did you seperate the driveshaft at any time when it was removed from the car?
Old 02-25-2013, 07:57 PM
Yeah the rubber center bushing/donut got pulled and replaced with a new one. The drive shaft was separated and put back together with a new center bearing/bushing support by a import service shop. I marked the 2 sections and they had did the same and it appears they put it back like it was. The guy at the shop hart told me he had to manhandle it to get it apart. Any idea what a shop will charge to balance it?
Old 02-25-2013, 09:16 PM
if its back the way it came apart then it will already be balanced. unless the guy is lying to you. but they are balanced as a whole unit, each half piece isnt balanced individually. so you shouldnt have to do that. This one may be a little tricky to diagnose without physically seeing the car
Old 02-26-2013, 10:40 AM
Angry
Well it looks like that shop might of messed up the U- joint getting the drive shaft separated. It has a lit of play on one part and it appears the little seal cap was about busted off it. The guy at the shop is probably going to try to act innocent and refuse to do anything about it...
Edit: I'm not sure if they did it or if it happened when I test drove it. I know when I pulled it off the car two of the little rubber O-rings/rubber seals (where it now has a ton of play) had dry rotted and broke then fell off.
