E30 (1982 - 1993)
Rear camber kits
So I just bought the Ireland engineering rear toe and camber kit. Do I need special bushings for my trailing arm? Or do the camber bolts work with stock bushings?
I bought the specialty products front adjustable camber plates. I plan on buying some rota wheels tonight and very tired of replacing tires. Anybody done the rear kits yet?
1985 335i ![]() Black on Black coupe 5spd Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap http://www.bimmerfest.com/forums/sho...36#post7573736 M20B27 for sale in Cincinnati |
You can use OEM or any number of aftermarket bushings. The adjustment is in the kit parts, not the bushings. I've install that setup. It works OK. Kinda finicky to set the toe/camber, but worth it once it's done.
What Rotas are you getting?
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
ROTA TORQUE 16" for the front and 17" for the rear. With new Bridgestone tires, he's taking them off a MR2 so im pretty sure I won't need spacers. 7" wide front and 8" wide rears. I'll take pics tommorow.
1985 335i ![]() Black on Black coupe 5spd Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap http://www.bimmerfest.com/forums/sho...36#post7573736 M20B27 for sale in Cincinnati Last edited by Newman271; 02-07-2013 at 08:46 AM. |
I have a set of Rota Circuit 10s, 16"x 8". I swapped set of bottle caps for them! Some ricer had them on his Honda and decided he wanted BMW bottle caps instead! I was like
but took the deal.
Nice! Im gonna figure out if they fit without spacers or major mods tonight. But dropping the rear axle and welding for the camber and toe kit doesn't sound like fun.
