E30 (1982 - 1993)
Old 02-06-2013, 06:34 PM
steezysloth steezysloth is offline
Mein Auto: 2000 323ci
Exclamation 89 E30 No Spark ):
So, ive got an 89 325is bone stock been sitting for 5 years ran when parked.
225k
turns over fine, new battery, new starter..
But for some reason i get no spark whatsoever!!!
I just replaced my main relay, some busted fuses, and a new flame thrower ignition coil and stil nothing.. i did a few tests and found out that i have no power going to the ignition coil.
Can someone maybe shed some light on my situation??? Maybe a common solution for this problem!
Please and thankyou!
Old 02-06-2013, 10:22 PM
BMWFatherFigure's Avatar
Old School
CPS, or two. Can be tested in place.
Current:
E38 Parts Car
Previous:
Old 02-06-2013, 10:38 PM
Well, i just found out the car needs allllll new hoses, for everything.. flush the radiator, a few different sensors, water pump, throttle body needs major cleaning.
As far as my ignition problem its probably the CPS i pulled it and it was coated in **** and old coolant, very nasty! Thanks for the reply!
Old 02-06-2013, 11:19 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
replacing the hoses and waterpump shouldnt be needed unless you havent posted all the information up you have of the car. would strongly recommend changing all the fluids coolant transmission engine diff and power steering oil etc
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 02-07-2013, 05:58 AM
Old School
Call it an Insp2 service + for starters. Then we will get back to making it run.
Current:
E38 Parts Car
Previous:
Old 02-07-2013, 08:57 AM
Hahah yeah, it was sitting for 5 years maybe longer and i bought it off some woman, interior is like it just came off the lot but the engine is a whole different story, looks like the coolant turned into little crystals...
Old 02-07-2013, 11:42 PM
Old School
MAJOR service properly carried out may fix all your problems in one go.. never buy a car from a little old lady!!
Current:
E38 Parts Car
Previous:
Old 02-08-2013, 04:44 PM
downhiller's Avatar
livin large
wait a minute.....those are the best ones to buy from since they dont know the true price of the car. but make sure she has at least the knowledge to service the car.
Old 02-09-2013, 06:04 AM
Old School
Ah, servicing. Isn't that where little old ladies start to not understand the car's go-roundie-bits?
Current:
E38 Parts Car
Previous:
Old 02-09-2013, 02:18 PM
its where 95% of second and third owner BMWs get it wrong
E30 above Sold
Old 02-09-2013, 07:45 PM
downhiller's Avatar
livin large
na, the older people grew up with having to get points adjusted and dino oil that needed to be changed. so they were used to having the cars in the shop
nowdays, service every 5000 miles, which the first 5k is a tire rotation then the 10k mark is oil and rotation.
Old 02-09-2013, 10:16 PM
Old School
Oh, how I yearn for the olden days...........
Current:
E38 Parts Car
Previous:
e30 ignition problem coil bad
