Old 02-06-2013, 10:22 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Just what I needed: Seat twist (drivers side front seat seems turned to the side)
I'm in the middle of a parasitic battery drain diagnostic sequence, snapping photos, when I notice out of the corner of my eye, something askew in the angle of the back of the front seat.
Is it ... uh ... can that be ... is it ... um ... is it the infamous malady ... is this seat back twist? Just what I need.
I had never taken much note of the seat twist threads ... but I guess I have some reading to do now, huh?
Here's the set I'll start with, from the bestlinks:
- How to identify seat twist & fix twisted seats (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13)
Old 02-07-2013, 05:10 AM
Chisum Chisum is offline
Mein Auto: 02 530iT/6 ZHP, 03 525i
It's and easy fix just time consuming.
Chisum
Fudman's Avatar
Fudman Fudman is offline
I have never followed seat twist threads either. Good luck, BB. Looks like you have your hands full!
Does anyone have any idea what causes a seat twist? Was this seat twist caused by adjusting the seat length or angle (slipping off the track)? Or from leaning into the seat to access something under/in the dash? Or does it just happen (a component, like a gear, catastrophically fails suddenly) out of thin air? Also has this affected anyone with sport seats? I rarely move my seat and am curious if I am subject to this PITA malady.
Old 02-07-2013, 05:33 AM
The adjustment cable casing expands which pulls the end of the cable out of the motor. The fix is cut the casing remove about 1/4 inch of the casing then push the end of the cable back into the motor. The biggest part of the job is getting the seats out.
Chisum
Old 02-07-2013, 01:12 PM
SMG_II SMG_II is offline
Mein Auto: 2008 E92 335i/2002 530i
Sorry to hear that, I've gone through this on my driver's side, too, and actually my passenger side just did this to me last week.
In case it helps, I found link 8 (among other DIYs posted) above particularly helpful when I did this:
ElwoodBlues' writeup: http://www.bimmerfest.com/forums/sho...45&postcount=8
I don't know if this is true or not, but my indy said you should try to get the seat back into the best non-twisted position as soon as possible lest the frame get twisted permanently. Sounds like good advice, but I assume you'll probably take care of this long before damage like that happens.
Good luck with the repair!
Old 02-07-2013, 06:48 PM
540iman's Avatar
540iman 540iman is offline
resident, old fart
Mein Auto: 2002 540i sport
You do not have to remove the seat. As a matter of fact, don't even if you don't care about going that far as you might easily set an air bag service light. I just did this repair about 5 weeks ago. Loosen the seat rear bolts about 1/8" Remove the two front seatl bolts so that you can pivot the seat back (front raises up about 3" to gain clearance.
Chisum is exactly right about the cause, but removing the seat is just not necessary. Using the seat back tilt button, determine which motor drives the seat back. You must feel the cables and see which one is moving the seat and which one is the "lazy one" and not doing its share of the work. Trick is that you must raise or lower the seat back until the seat back is even across. You can measure distance to dash or just go with what feels right sitting in the seat. Once seat is even- regardless of whether seat is way tilted back or too straight up, the seat must remain in this position.
Now, the cable you determined is not doing its share of the work- disconnect it from its motor by simply twisting off the retaining ring at the motor. Using a soldering pencil or gun, melt away about
3/8-1/2" of the outside cable sheath. Using a utility knife, clean away about 3/8" of outer cable covering. This will allow the center part of the cable to not be restrained from engaging the motor drive. The outer cable covering has stretched such that the metal inside the cable is pulled out of the motor. By removing the outer cover some, the cable center will now engage itself as soon as you re-tighten the retaining ring. As long as the seat was straight when you started, it will now go up and down in "sync". You can search seat twist for pix. I am just reiterating what Chisum said and the fact that you need not remove the seat. Now just tighten down the seat again. You can wrap the cable where the surgery was done with electrical tape and then using a zip tie, put cable back in snug.
Old 02-07-2013, 06:55 PM
Ltmax's Avatar
Ltmax Ltmax is online now
Mein Auto: 2008 750l
Don't worry too much, this is a very simple fix and you can do both in just a few hours and that's taking them out of the car. In the car is even faster, but I'm not a fan of cutting the cables in the middle as I've had to fix a few a second time that eventually went bad (damaged/kinked the inner shaft/cable) that were fixed this way a few years down the road. If you do decide to remove the seats, it's also best to go ahead and trim a little bit off of all four cable ends (two underneath seat, and two on side of seat) so you never have to worry about doing it again. (Learned that lesson the hard way too..)
Plus taking the seats out gives you such a great excuse to clean away the years of crud and other stuff from the areas of the carpets that you just can't get at when they are in the car....
Old 02-07-2013, 10:13 PM
bluebee's Avatar
Thanks for the advice & admonishments.
Right now, I'm working on parastic battery drain, and then it's a new expansion tank.
Once I get those two critical items fixed, I'm going to attempt the seat twist repair.
So, any and all advice as to how to minimize the damage until those two are done, is welcome!
Old 02-08-2013, 09:04 AM
EddieNYC's Avatar
EddieNYC EddieNYC is offline
-Eddie
Send a message via AIM to EddieNYC
Mein Auto: 2003 530i
It is very easy. Can be fixed with minimum tools and lots of patience!!
Done it 4 times already..
Old 02-08-2013, 10:23 AM
540iman's Avatar
resident, old fart
If you do decide to pull the seats, just make sure step#1 is disconnecting your (dead!) battery. Then, when you go to remove the seat, the piano wire that is connected to the seat that tells the air bag system where your seat is at relative to the dash (is the seat forward, in the middle, or back) can retract without setting an airbag arror. This wire is part of a linear transducer that keeps tension on the wire at all times like the pull-out dog leashes that retract automatically to not let there be slack between yourself and the dog. This wire will retract as soon as you disconnect it. Then you can disconnect the motor connectors and pull the seat. I prefer to leave the seat where it is. I can certainly see where removing the "extra" cable sheathing close to the motor rather than somewhere in the middle would prevent the now hacked-up cable from kinking at that point, but if you secure the cable snug on either side of the surgery area with cable ties, the cable should not be able to kink at the area of the work being done. Removing the 3/8" of outer wrap in easily done with a soldering pencil or soldering gun and then clean-up the melted "goo" with an exacto knife or utility knife just to make the area smooth and clean. When you search "seat twist", you will get a better post with pictures of what you are doing. I am too lazy to take pictures when I am working on my car-sorry. Hopefully someone else's pictures and my narrative will make what you need to do very clear. Bee, you really need not worry about this DIY as it is one of those that sounds harder describing it, than it really is! G/L
Old 02-08-2013, 05:11 PM
bluebee's Avatar
This is great to know because I like to line up my ducks before I do any job. Of course, that means it takes me far longer than anyone else, but, I do learn things which you guys already know somehow.
It's encouraging that you say it's easier than it appears to be - because the seat is something I've barely touched (other than the seat control panel on the side).
Right now ... I'm reading up on this... and hope to approach it this weekend if the weather cooperates.
Old 02-08-2013, 05:33 PM
Studawg's Avatar
Studawg Studawg is offline
Mein Auto: 2003 540iT M Sport
Its very easy, both of my front seat were twisted as well as the height control of the seat bottom only worked on one side, on both seats too. So 4 adjustments were broken, I fixed them all without removing either seat, or any bolts or anything, by using a pair of wire cutters and a razor blade in a pair of small vise grips. Took about an hour. Check out the video on youtube about it.
diagnostic, leather seats, seat back assembly, seat repair, seat twist
