E46 M3 (2001-2006)
Old 02-06-2013, 11:01 PM
IEbimmerguy's Avatar
IEbimmerguy IEbimmerguy is offline
Mein Auto: E38, e23, e3
2002 M3 with P0012 code
Hi all, I've been chasing down a sudden rough idle with my M3.
Upon first reading the codes, there were 17 of them. Ranging from misfires on all cylinders, to random misfires, to p0012, and p0014.
I thought it was the Vanos coil pack, so I replaced that with one from Beisan systems. I also cleaned out the solenoid valve block, changed out the intake CPS with a new BMW unit, and still have a rough idle and now code p0012 instantly.
I removed the valve cover and looked for the broken tabs, loose bolts, and everything looks fine.
Is this a Vanos failure? Anything else I'm missing that you could suggest?
Thanks!!
Old 02-17-2013, 03:18 PM
redlineteche30 redlineteche30 is offline
Mein Auto: 1987 325e
I would do a smoke test to check for vacuum leaks. If you are using certain odb scanners they will register P0012 and associate it with fuel trim codes for unmetered air
Sent from my DROID RAZR using Bimmer App
Old 06-02-2016, 06:43 PM
GetS0M3 GetS0M3 is offline
Mein Auto: 2003 E46 M3
Thanks!!
Did you end up finding the problem? I just encountered the exact same problems and dont want to start throwing parts at it.
Old 06-05-2016, 06:33 PM
mstaj mstaj is offline
Mein Auto: BMW
I've got the same code p0012, Looking at replacing the camshaft position sensor.
