Old 02-07-2013, 11:01 AM
CA540 CA540 is offline
Mein Auto: BMW 540i
2002, 540i Won't start, intermittent...
My 540 6MT sometimes doesn't start. Turn off key, turn back, still no turn over. Then,
3rd or 4th time, turns right over. go two weeks, starts fine, then one day, same no start, try again, and it starts.
It feels like a dead battery but would the battery quickly come back to life?
Any help appreciated. Thanks.
Old 02-07-2013, 11:39 AM
mbell666 mbell666 is offline
Mein Auto: e39 2002 540i6
I'd go for ignition barrel or clutch pedal switch. Car will not turn over unless you have the pedal down, fault switch could cause it to believe clutch is not down.
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it.
Old 02-07-2013, 11:50 AM
HTK12 HTK12 is offline
Mein Auto: E39 540i
I would start by pulling the codes.
Old 02-07-2013, 08:00 PM
stephen bruke stephen bruke is offline
Mein Auto: 2001 bmw dinan 540i
i think you have a short on your positive battery cable. next time that happens tap/shake the battery cable and it will work.
