Old 02-28-2013, 09:23 PM
daytradeoil daytradeoil is offline
Mein Auto: 2001 bmw 525i
Telescoping wheel moves up and dome light turned on while driving....
Just got off the freeway. Telescoping wheel moved up and domelight turned on as if i took the key out of the ignition. Cruise set at 70 change lanes and bam. Move back over a lane turn off cruise and again. And again. And then one last time but only the dome light turned on.
I think something electrical is loose. It happened when the road was bumpy or changing lanes hitting the lane markers. Ill search and see if i find anything but boy was that scary.
Old 02-28-2013, 09:56 PM
Ummm windows arent working either apparently. Central locking works. If i open a door and close it the dome light stays on. Guess i have another weekend working on her
doru's Avatar
doru doru is online now
Mein Auto: 2003 530iA
I think the ignition switch might be done.
Old 02-28-2013, 10:02 PM
Turned off the ca and the wheel didnt move up. Turned it back on windows worked but the one touch auto roll didnt. Im guess a loose fuse or wire somewhere.
Old 02-28-2013, 10:13 PM
Hmmm possible. I tried the sun visor test on my way home and nothing changed. Just got home and forgot my laptop at work! Booooooo. Ill reseat all fuses in the am just in case and hope i make it to work with out a major hiccup.
Old 03-02-2013, 12:46 PM
so yesterday morning i pushed in all my fuses. fuse 5,6,7 area is where the issue was. after looking up what the fuses did it was either 6, 7, or both. when i pushed this area this area the steering wheel moved up then back down.
so i pushed it in and all has been good so far. if any other issues arise however ill be quick to get on the ignition switch.
hope this can help someone in the future.
Old 03-02-2013, 06:01 PM
cn90 cn90 is offline
The symptoms will be back and you will head to BMW dealer to buy a new ignition switch.
Old 03-02-2013, 06:45 PM
rcmarty rcmarty is offline
Mein Auto: 03 540 M sport
I replaced my ignition switch also. I had the visor crazyness in mine.
Another possible thing to look for is the connection on the side of the seat. It does the bi rocker. My front screw holding in the trim came loose/broke the little tab off i assume.
Anyways it was loose and with a few times in and out of the car i managed to half unplug the connector.
This connector loose caused all kinds of weird stuff including the sterring wheel.
Just another spot that causes havoc
martin
Old 03-02-2013, 06:51 PM
Sgrim Sgrim is offline
Mein Auto: 97 328i, 2000 528i Sport
I had same issue. Sun visor test did not work every time it did it. Some other things that would happen are: stereo shuts off, brake lights would come on, brake and abs light in dash would also come on. I purchased a ignition switch from local BMW dealer and for $82.00 and 20 minutes of my time, the issues were all fixed. Hope this helps and good luck.
Old 03-02-2013, 07:18 PM
So far so good. Almost 200 miles. When and if it comes back ill get the switch.... Hopefully the fuses were the issue.
Thank u all
