E60 (2004 - 2010)
Old 02-12-2013, 11:04 AM
ankurg09 ankurg09 is offline
Mein Auto: BMW 530i
Disconnected battery before Removing Seat
Kicker , OEM and LOST
Installed!!!!
Old 02-12-2013, 11:05 AM
Mein Auto: BMW 530i
Car was really messy , didnt realize how much stuff gets stuck on the sides. Used some carpet cleaner to remove coffee stains
Old 02-12-2013, 11:21 AM
bimmerrg bimmerrg is offline
Mein Auto: 535i
What kind of tools are needed to remove seat? Do we need to just remove the 4 bolts or more? After the work done, are the seats going to stay tight without moving on stops?
2009 535i Black Saphire Metallic/Natural Brown/Prem pkg, Sport pkg, comfort access, Navigation, Sport Transmission with Shift Paddles, PDC, Heated Front Seats, iPod and USB Adaptor, Satellite Radio, BSW Stage 1 Speaker upgrade, JBL MS8 DSP, Technic Harness and BMW Individual co-axial center speaker ==> Superb Custom LOGIC 7, New Michelin Pilot Sport A/S tires! Route 66 Extended Warranty till 5+yrs:1/26/2018 or 100k miles.
Old 02-12-2013, 01:14 PM
Mein Auto: BMW 530i
4 bolts and cable coming from floor to the seat, I guess u need T25 socket ( can check and let you know or if you are in us you could just go to Autozone and they would test and give you one) you would also need a breaker bar and a ratchet. I did not remove the seat belt mounting screw since i just lifted the seat and kept it close to the car with belt extending(not sure if this is the right way).
After work seats are the same as before. Just make sure before unplugging any cable from seat , Remove the battery -ve terminal and let the car sit for 10 minutes (minimum).
For more info , I have attached the seat removal guide.
File Type: pdf Master_removing_and_installing_front_seat___normal.pdf (389.2 KB, 48 views)
Old 02-12-2013, 08:56 PM
H F H F is online now
Mein Auto: 2005 545i
What exactly are the componets you used: make and model, Please. Are these plug and play?
like Ankurg said contact Tecnic for the harness and will plug and play any after market amp u like. unfortunately i didnt find that out till after i hooked up my system. and taped into my factory harness.. two years ago
to answer ur question,,, im running a EFX 300c4 , 4 channel amp hooked up to the factory speakers. the underseat woofers are now wired as mids ,,,
The additional equalizer is a AUDIO CONTROLL FOUR.1i it works really good and gets amazing clarity on the factory system... i recomend it to anyone installing a system in their cars... the factory speakers actually are really good once u add a little pwr to them...
My second amp is a EFX 500c.. one channel amp runs my 10 inch.. Cerwin Vega woofer ,
I made a mdf one inch thick custom bandpass woofer box with a 4 inch port goen thru the plastic arm rest cover thru the back seat.. that way all the sound from the woofer goes staight in the cab.. and sounds bad ass.. and the best part is u cant hear it at all out side the car.. untill i open the doors.... well hope my info helps u out
Old 02-15-2013, 02:37 PM
Mein Auto: 535i
Thx for the details.
One question on non folding rear seats I have. How can the wiring can run from door sills into trunk? Is there a easy way? I am clear on front to back but not clear on back into trunk!
Old 02-15-2013, 05:33 PM
the only wires ive ran are from the trunk to the cab... which are the cable to the woofer controll knob.. the remote wire to a swith to cut off pwr to both amps .. and i also ran pwr to my iphone/ipod cable... if u remove the seat cushion there are cables running into the trunk on the pasanger side allls i did was pull the bottom of the back rest out alittle and ran the wires thru there. if u take out the trunk matt and the side cover ull see all the wires goen into the cab..
Old 02-18-2013, 09:48 AM
Mein Auto: BMW 530i
Working on the trunk wall to mount amps
Test Fitting the wall in the trunk
Could not use the speaker adapters that i bought initially cuz L3se's are smaller than regular 4" midrange, so making my own speaker rings
Old 02-18-2013, 09:49 AM
Mein Auto: BMW 530i
drilling holes for the wiring.
Old 02-18-2013, 10:00 AM
Mein Auto: BMW 530i
Audison Distro Mounted and wires ran from behind the wall
Arc Amp mounted and wired. MS8 to go Next
Backside
Old 02-18-2013, 10:03 AM
Mein Auto: BMW 530i
All the wiring / RCA's / Speaker wire hooked up. I guess should have ordered a little shorter RCA cables , hope this loop doesn't cause any issue.
Old 02-18-2013, 10:05 AM
Mein Auto: BMW 530i
My dog getting bored while I work
Old 02-18-2013, 12:13 PM
burnie35 burnie35 is offline
Old Timer (Really)
Mein Auto: 2009 BMW 535i Sport
Personally, I'd rather hear the "growl" of the engine that the "thump" of a sub-woofer.
BMW CCA Member
2009 535i Sport, Jet Black | Cobb Stage 1 | BMS Drop-in Filter | BMS Led Angel Eyes | Michelin Pilot Sport A/S Plus (no runflats)
2008 528i (Retired)
2006 328ci (Retired)
1975 US Army (Retired)
Old 02-18-2013, 12:19 PM
Mein Auto: BMW 530i
Me too if I had an exotic car or even an M5. On a 530 not so much
Old 02-18-2013, 12:30 PM
Mein Auto: BMW 530i
OK now to the doors. Front doors and Tweeter Sails disassembled
Old 02-18-2013, 12:38 PM
Mein Auto: BMW 530i
Hybrid Audio Technologies L3se next to OEM
Dynamat and speaker installed
Had to tear the Tweeter sail to get this Rainbow SLC to fit snugly
Rear Door
Till this point I didn't decide where to mount the crossovers for speaker and tweeter
Old 02-18-2013, 01:20 PM
schpenxel schpenxel is offline
Mein Auto: E60 - 545i
good lawd
Old 03-29-2013, 08:52 PM
Rob3980 Rob3980 is online now
Mein Auto: 2008 BMW 535xi
I forgot about this thread how is the build coming along? Pics? Questions for ya what exactly does the mobridge do? I'm about to start my build I have hertz mlk2tm for my fronts a hertz hp5 amp and a sub I want to keep all my stock speakers that I'm not replacing running off the stock amp and I want to just be able to Intergrate the hp5 but still keep all the functions of the logic 7 is that possible and if so what all do I need? I was told a bit ten but then I was told a bit ten and the mobridge ?
Performance: JB4 G5 ISO / BMS DCI / AR DP's / BMS WW Meth kit / ER CP / ER FMIC / HKS BOV / BMS OCC
Exterior: Avant Garde M310 wheels / Window tint / mtech halo upgrade / Sprayed tail lights & side markers / M5 front and sides / Front Lip Spoiler / Kidney Grills / Black BMW logos / LEDS
Interior: Custom gauges done by Simon
Soon to come: RB Turbos / V3 coil overs
Old 03-29-2013, 09:17 PM
mp96b mp96b is offline
Manny
Mein Auto: 2010 BMW 528i xdrive
Technic harness
Old 03-31-2013, 05:06 PM
Isn't a technic harness only for adding a sub and amp not a while system?
Old 03-31-2013, 07:33 PM
Manny
Sorry replied to wrong thread
Old 04-01-2013, 06:58 AM
Mein Auto: BMW 530i
Hi , The build was completed long time back, forgot to update the thread. Adding Pics soon.
Mobridge , connects to the fiber optic signal going into your amp and gives you 8 ch of RCA's with Fade and balance. It basically removes the logic 7 amp and gives you RCA outs to connect aftermarket amps.
If you connect mobridge you will loose your stock amp. You could just get a Technics harness and connect that to power underseat woofers , sub. Since Technics harness taps into the underseat woofers you should be able to use the same signal to power the front Hertz speakers . Just remember to set the HPF for them on the amp( around 150 to 250 based on your speakers capabilities). It would give you better than stock sound but to get the absolute best you would need to add a processor like Arc PS8 or JBL ms8 or Bit one.
I will be honest I did have a tough time tuning MS8 but once I got some stuff figured out , I was able to tune it to where my system sounds fantastic.
Good luck with your build , let me know if you have any questions. Keep us posted with Pics
Old 04-01-2013, 07:04 AM
Mein Auto: BMW 530i
Setting up Mobridge
Finished Trunk
Old 05-08-2013, 06:41 PM
BMWmojo BMWmojo is offline
Mein Auto: 2006 530i
Smile
Rear Door
Looks like there could be some room to install a 5.25" speaker at the bottom of the door panel...
Old 05-08-2013, 06:43 PM
ankurg09
Nice demo!!!
