Old 02-07-2013, 05:50 PM
boyer357 boyer357 is offline
Boyer357
Mein Auto: 745i Grey Sport-Black int
Lag and Hesitation with throttle 02-745i
HI,
First this forum has saved me thousands on repairs and mostly allowed me to drive one of the most beautiful luxury cars out there.
The car has a hesitation and lag under throttle but notice no tach difference.
It Has 88k have owned for 4 years. Have taken to autozone for thier free diagnostic and
no error codes. Tried Lucas injector cleaner-no change-collant levels have been steady but
did add about a pint since a flush and 3k miles
My questions:
-could it be the spark pluggs?
-Fuel filter?
-is it worth taking to BMW dealer for their diagnostic? how much$
-or the dreaded weep hole
-reflash software-
Thank you
Boyer357
Old 02-07-2013, 07:41 PM
Boyer357
Help!!Lag and Hesitation with throttle 02-745i
HI,
My questions:
-Fuel filter?
-reflash software-
Thank you
Boyer357
Old 02-07-2013, 07:46 PM
Ltmax's Avatar
Ltmax Ltmax is offline
Mein Auto: 2008 750l
First thing I'd do is clean the MAF sensor and put new plugs in it and see if that helps.
Old 02-07-2013, 08:24 PM
Boyer357
Thanks -im guessing MAF is something you can do yourself-and of course plugs
Had read that no reason to change them if no cylinders are misfiring--
appreaciate it and wil repost
Old 02-07-2013, 08:32 PM
Ltmax's Avatar
Cleaning the MAF is very easy, take off the air filter hose assembly and spray some MAF cleaner onto the sensor located inside the hose right next to the throttle body.
Mine started idling rough when I'd first start it up and felt down on power and after two trips to the dealer who said "it's normal" I cleaned the MAF and the problem went away.
With 88k miles on the plugs they are due to be replaced. Just don't use the real cheap Denso Irridium one's that cost a few bucks a piece or you might be pulling them out in a few weeks like I had to do on two of my BMW's that started giving me misfire codes right after putting them in. It's funny, I've used them on many other cars without a problem but for some reason the BMW's seem to not like them so I recommend sticking with either NGK or Bosch plugs if you can and gap them at .032 thousandths.
ID:	361314   Click image for larger version
Name:	bmw maf cleaner.jpg
Old 02-07-2013, 08:33 PM
Ultimate745i Ultimate745i is offline
Ultimate745i
Mein Auto: 2004 745i
I'm not one of the better informatives on here but I'll get the ball started with what I do know:
1) Autozone diagnostic doesnt get into the DEEP coded issues. You may need to take it to someone else like a dealer or someone who has the proper program.
2) the weep hole is simply a coolant LEAK in a tube under your air intake but doesnt effect overall performance.
ok...sumbody else jump in..that's the extent of my mechanical assistance.
Fun Doesnt Come Cheap!
Old 02-07-2013, 08:40 PM
perryj43 perryj43 is offline
Mein Auto: 2002 745IL
Your problem might be with the programming connected with the accelerator, you might want to try this software reprogramming:
http://www.sprintboosterusa.com/c-57-at-m-series.aspx
Old 02-07-2013, 09:03 PM
Boyer357
Much thanks--I must say the members here care cuz they luv their rides-
I will try tommorow and post--again thank you for the details-its truly appreciated
and helps from a trip to the stealership.
Old 02-07-2013, 09:09 PM
Boyer357
sorry reposted
Thank you --I reposted this --with help--thinking no one would reply--but I should know better --appreciate it sincerely and will repost--just havent found a post that really adresses this issue--much thanks
Old 02-12-2013, 10:15 AM
Boyer357
engin hestitation between 20-40 mph
Cleaned MAF -noticed no difference-
same problem -serious lag and hesitation between 20 and 40 mph. no real problem when car is at 50 -80mph.
No problem starting car and idling.
Would old plugs cause this?
Old 02-12-2013, 10:35 AM
alpinaman24's Avatar
alpinaman24 alpinaman24 is offline
what amg?
Mein Auto: 07 B7,91 735i , 91e30sold
vanos seals ..
Old 02-12-2013, 10:36 AM
First_745Li's Avatar
First_745Li First_745Li is offline
Mein Auto: 2007 Audi A8
Fuel filter, maybe?
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Old 02-13-2013, 08:38 PM
Boyer357
  • Only happens btw 20 and 45 mph
    Have checked tranny by driving in manual 2-5 gears same problem
    Would bad spark plugs cause this?
    Idle fine
    55-85+ no problem
Old 02-13-2013, 09:23 PM
jcharris jcharris is offline
If you have over 150k miles, replace the Vanos and you it should come alive again.
2002 745I
Outrageous Daytona paint
Forgiato Rasoio
Drilled/Slotted aftermarket rotors
2006 Nissan Armada
Basic Silver
Gianna Wheels
JL Audio System/ Headrest monitors
Old 02-14-2013, 06:29 AM
Ltmax's Avatar
I'd keep with the basics and swap the plugs next since they are overdue to be changed and see if that helps.
Old 02-15-2013, 06:54 PM
riff riff is offline
Mein Auto: 745i, 330Xi
Before you spend cash try this:
put the fob in the ignition
push the start button once with the car off and your foot off the brake (i.e., do not start the car)
press the accelerator to the kick point (or the floor) and hold for 25 seconds
start the car
drive and test
NIH - I got this info off another DIY forum on bimmerfest. It worked for me.
Old 03-16-2013, 03:55 PM
cravin2012 cravin2012 is offline
Mein Auto: 2003 745iL
I know this is a very old thread... But were you able to solve the issues??? If so, what was the solution???
Old 12-27-2013, 04:54 AM
Joe750's Avatar
Joe750 Joe750 is offline
Mein Auto: 750li
The only bad part about the forum sometimes is people don't finish the posting there results !! So it's almost a waste of time --
Let me try ! Did you ever find out your problem ???????? And if you did or didn't can please update us ?????
