Old 02-08-2013, 11:27 AM
alibear alibear is offline
Mein Auto: 2001 BMW Z3 3.0
Convertible Top Malfunction
Hi everyone! I have a 2001 Z3 3.0 convertible. The top is motorized, up/down buttons are between the driver's and passenger's seats. It's been working perfectly, but this morning I went to put the top down and nothing happened when I pressed the buttons. Should I check for a blown fuse first? And if so, where would I locate the fuses? I bought this car used and it didn't have the owner's manual with it. Any other ideas if it's not a fuse? Would like to see if I can solve it myself before taking it in to the shop. Thanks!!
Old 02-08-2013, 02:50 PM
AlanZ3 AlanZ3 is offline
Alan
Mein Auto: 2001 Z3 3.0i
From a previous post:
Fuse F46 provides power to the brake light sw, when the pedal is depressed, the sw passes pwr to the one side of both open/close relay Coils. (the other side of the coil is connected to the top open/close switch then thru the top limit switch to ground)
Old 02-08-2013, 03:38 PM
khammack khammack is offline
Warning - Thin Air
Mein Auto: 2002 M Roadster/2014 435i
There is also a micro switch just above the driver's head that is known to fail. It tells the system when you push the top up before lowering it.
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Assistance Pkg, Prem Pkg, Tech Pkg, 8 Speed Sport AT, Heated Front Seats, Active Cruise Control, BMW MPPK w/MPE, BMW Limited Slip Diff, BBS CH Wheels.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels.
Old 02-17-2013, 06:50 PM
atopa2002 atopa2002 is offline
Mein Auto: 2009 e90 335i
When mine failed it was the relay near the pump in the boot . do you hear the pump working ,if yes you have to push the tip of the top to initiate the folding.also check if your break light is on then the break pedal is pressed, if yes then connection between pedal and the pump electronics is intact.
Good luck.
