E30 (1982 - 1993)
i need a good lowering kit??
Plain facts: you can get parts to lower the car for cheap, but it won't handle or ride well as it could or should. You can spend a decent amount and lower it and at minimum maintain the handling it has as it sits. You can spend quite a bit on really quality stuff, drop it to exactly as much as you want, and substantially improve the handling. Your car, your money. You chose.
Cliffs version: you get what you pay for. Sent from my MB860 using Bimmer App
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
Well I'm all about quality so I'd like to lower it exactly as much as I want as well as improve the handling. So with that figured out what do you recommend.
Sent from my SCH-M828C using Bimmer App |
H&R lowering springs, bilstein struts and shocks(sports), front camber kit, rear camber and toe kit... I did all this and upto about 6-700 so far... gettin alignment next week.
1985 335i ![]() Black on Black coupe 5spd Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap, Mustang GT Injectors, Port/Polish
There's also this kit I've been looking at: http://www.bmpdesign.com/product-exec/product_id/524/category_id/143/search_year/1989/search_model/34 The drop is 1.3 inches, I'm not sure if that would do much for performance though. I drive an 89 325i and would like to lower mine for performance. Anybody know the optimal hight for the best performance? |
how much will that lower my car? and if its not to much trouble could you send me some links to where you got your parts
http://www.pelicanparts.com/bmw/cata..._pg2.htm#item9
Thats for springs and struts. http://www.spcalignment.com/componen...AFrom&to=USATo Thats for the front camber plate.. atleast thats what I bought. http://www.iemotorsport.com/bmw/E30-...-steering.html Thats rear camber and toe kits.
im really interested in this kit a little pricy but they have great customer service and it sounds like i wont need anything else but this kit so sounds good to me
http://www.ground-control-store.com/...ion.php/II=754 |
Ground Control is where its at. Coilover conversions or a whole set of coilovers. You can literally make your car handle worse by dropping it.
can you clarify what you mean by that.
Ground control or making your car handle worse?
Ground conrtrol is a company that makes good quality suspention. The wrong setup can make your car handle worse, shocks, spring rates, camber is very important to how a car handles.
Unless your building a track car.. no need to spend all that money on coilovers to drive to work or school. I can almost promise you a good set up of springs shocks and alignment would be better to cheap coilovers. I've had tein coilovers on a integra with in-c-o-c-k pit controls, came with the car. It was nice for AutoX but not so nice for everyday. Too stiff and ended up replacing control arms and ball joints left and right. Sold that car for a awd dsm. --Best way to upgrade your suspension, stopping power, and acceleration is to buy Great Tires!--
so then what are you recommending i need the track wil be on the track just not full time and i do want it lowered. please attach links
For interest sakes:
How many people actually adjust their adjustable suspension for proper handling ? How many of that first group actually adjust their suspension frequently for different situations ? Just curious
Use Google next time its a bit easier for both of us.
I do adjust suspension to match tire and rim setup, running H&R's.,
GC's are a great bargain for what you get and are good quality with great customer service. go at it progressibly as funds come available. - springs and shocks, (add or substract spring pads if need be as they do come in various thickness) or get coilover sleeves. - offset CAB - camber / caster plates and adjustable TA bushings. Last edited by fporro; 02-15-2013 at 12:24 AM. |
