Old 03-17-2013, 03:26 PM
haastx10 haastx10 is offline
RocknDoc
Mein Auto: 2015 M5 DINAN
Auto close Sunroof & Shade
Built in feature discovered by TopDownInFL...
If you quickly slide sunroof switch to "Close position" twice it will shut both sunroof and shade. If you push "Up" twice it will move sunroof to tilt position and leave shade partially open to promote airflow.
http://www.bimmerfest.com/forums/sho...93#post7450293
________________________________________
2015 BMW F10 M5, Space Gray, Dinan Stage 1 Engine, Exhaust, Coil Over Suspension, Sway Bars, Vorsteiner Staggered 9 /10.5 '20's, Custom Coded.
Old 03-17-2013, 03:42 PM
jeffnin jeffnin is offline
BMW Addict
Mein Auto: 16 750i, 15 i3, 15 428GC
Works for all BMW's with the electric sunshade. You can also quick-open both the shade and sunroof together by quickly double clicking the switch to Open. Works in both directions. Another of those undocumented tips
2016 750i Black Sapphire/Black|Driver Assist Plus|Driver Assist Plus II|Executive Pack|Interior Design Pack|Wood inlay Wheel|20" M Sport Wheels|Integral Active Steering|Display Key|Ambient Air|Pano Sky Lounge|Bowers & Wilkins
Past BMW's: 15 335i, 13 740i, 12 328i, 12 X5, 09 335i, 07 X5, 07 335i, 04 545, 01 525i, etc....
Old 03-17-2013, 04:27 PM
dbs600 dbs600 is offline
Mein Auto: 2011 750LXi Individual
Is there any way to have the roof tilted up, but the shade fully retracted...?
Old 03-17-2013, 04:40 PM
BMW Addict
No, you can only tilt the sunroof with the shade at least partially open. With the shade closed, just press the venting button and the shade opens adjust a bit to allow for air to circulate.
Old 03-17-2013, 06:40 PM
That's annoying; I'd like to be able to tilt the roof up, while also having the shade fully open...
Old 03-17-2013, 06:43 PM
BMW Addict
Sorry, I misread your question. You can use tilt with shade fully opened. I thought you were asking if you could use tilt with shade closed.
Old 03-17-2013, 08:04 PM
Snorlax Snorlax is online now
Mein Auto: _
Nice reminder. Thx.
