Old 03-05-2013, 12:37 PM
B_RASHED B_RASHED is offline
b_rashed
Mein Auto: 2009 750li
Originally Posted by haastx10 View Post
Presumably the front springs are the same for all the 750's, but the Li car should have self leveling rear which requires rear leveling rods and not rear springs. The correct kit for your application is Part #: 28999-5. For more info go to;
http://www.turnermotorsport.com/BMW-...r-springs.aspx or
http://www.hrsprings.com
By the way Turner is running a 10% off special on all H & R springs this month.
Good luck!
Thank you. I found the set for $140.
Vehicles
2009 BMW 750LI (current)
2006 BMW 650I Convertible Sold- Dinan Stage 3, Full Throttle Body, Carbon Fiber Dual Intake, M6 Kit, LCI headlights and tailights, H&R lowering springs, 19" M6 wheels, custom magnaflow exhaust
1998 528I sold- hamann lip kit, euro headlights, custom exhaust
Old 03-09-2013, 01:25 PM
haastx10 haastx10 is offline
RocknDoc
Mein Auto: 2015 M5 DINAN
Got the springs installed and here is how it looks... Sorry pics aren't the best but give an idea. Car going for alignment and headlight adjustment next.
Alignment done... No need for any other adjustments! Here are some better pics of the lowered car. You can see that there's still plenty of clearance with the stock 20's from the fenders... but about 1.5 in drop from stock. Significant improvement in handling including steering response which feels much crisper! No no significant deterioration in ride quality either...
ID:	365544 Click image for larger version
ID:	365545 Click image for larger version
________________________________________
2015 BMW F10 M5, Space Gray, Dinan Stage 1 Engine, Exhaust, Coil Over Suspension, Sway Bars, Vorsteiner Staggered 9 /10.5 '20's, Custom Coded.
Old 03-09-2013, 02:29 PM
htn htn is offline
Mein Auto: 13 750i
Attachment 365544 Attachment 365545 Attachment 365546
looks Fantastic! Way better. Can you pls take pics directly from back. I wonder how your wheels caved in after the drop as I have the same. Thanks.
Old 03-09-2013, 03:39 PM
b_rashed
Just got mine in. I'm only going to be using the fronts for my LI so ill be looking at getting the rods for the rear very soon and begin install.
Vehicles
Old 03-16-2013, 06:19 PM
RocknDoc
Here you go... Typical german negative camber configuration... Was way off after change of ride height but 100% in the green after alignment.
ID:	366722 Click image for larger version
Compare with vertical lines on post next to tire and building in background...
Rides and drives perfect! No regrets!!!
Old 03-17-2013, 02:48 PM
htn htn is offline
Mein Auto: 13 750i
Thanks for the shots.
I was imagining the wheels would be sunk in.
Looks really good. I will be doing this soon.
Hope you don't mind sharing cost for shop to do the install.
Old 03-17-2013, 03:01 PM
b_rashed
I just ordered my lowering links today. Should be here within the week. I should have pictures of the cars drop by the weekend.
Vehicles
Old 03-17-2013, 04:13 PM
RocknDoc
Runs about $450 for install... and another $150 for BMW to do 4 wheel alignment after... well worth it just look out for dips in the road, curbs, and driveways!! One benefit... park sensors now pick up the edge of curbs but you have to turn them on when pulling up to one. Also, you'll want to adjust your headlights up a bit... Just mark the height on your garage door and afterwards adjust them to this level... The vertical adjustment screw for the drivers headlight is under a small plastic cap in the fender to the right of the light (when standing in front), the adjustment for the passengers is again to the right of the light inside the access panel for the lamp housing. The other adjustment screw moves the lights left/right.
Good luck!!!
