Old 02-08-2013, 12:30 PM
daverp daverp is offline
Mein Auto: 2007 328i
Shudder between 1500 and 2100 rpm under load? Transmission or other?
So, I was on here a while back with a separate issue with stalling I seem to have corrected (sticking vanos solenoid) . Finally got a code on that (P1554). Changed oil, cleaned and swapped solenoids to see if it would go away or if swapping would result in a different code. Seemed to run a little better, no stalling, code disappeared after a few days.
I still have a shuddering. It happens at various speeds in gears 4,5,6 it seems, when cruising at speed (from about 30 to 60, depending on gear). All is fine until engine loading increases slightly when in the 1500 to 2100 rpm range (usually hits about 1500 or so, and again at 2000, all gears). Crusing along, slightly depress pedal to keep up speed, and the shuddering starts. If I push the pedal through it and accelerate harder, it stops.
It's not a constant shuddering, but lasts several seconds, on and off, as the car works its way though that rpm range.
If I put the car in sport mode, and manually select a gear that keeps it in that rpm range, the shudder is still there somewhat, but much less noticeable.
Car has 135k miles on it. 2007 328i. Was regularly serviced by dealer through 100k miles.
Ideas? I'm thinking of taking it to an indy tech this weekend, but would like to know what possibilities exist here, and if there's anything I should try and DIY first?
Old 02-08-2013, 05:45 PM
Banned
Mein Auto: 2007-335 HTC
trade it on another car, its not like it a classic, unless you plan on keeping the car for EVER, dont waste any money on it, if it doesnt keep you from getting from point A to point B then dont worry about it, drive it and get use to it.
my opinion and I have spent tons of money on a car thats worth 1/2 of what I spent on it
Old 02-08-2013, 06:07 PM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
Spark plugs?
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 02-09-2013, 01:47 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
Originally Posted by laser View Post
Spark plugs?
My guess would be a coil. But OP, get the fault codes read and eliminate the guesswork!
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof
Old 02-09-2013, 07:40 AM
fun2drive's Avatar
BMWCCA 149159
This shudder may not be an engine issue but that is a good place to start first. However the drivetrain might also be a place to look if you get no joy resolving the shudder.
The Guibo can provide the type of shudder you mention when it is worn out.
This might be a case where you don't get a code.
You mention this occurs under load which does sound like a coil issue but you didn't mention throwing a code which is a little confusing.
Failing 2ndary coils will start with a hot engine under load and continue to get worse.
Here is one thing that is typically a dead giveaway if it is a coil.
If you drive the car stone cold before the engine has warmed up at all does this happen?
If it doesn't happen until the engine is warm to hot that points to a coil.
If it happens all the time independent of the engine being cold or warm that is typically something else...
Old 02-09-2013, 10:10 AM
I'm going to have a diagnositc run on it today and an indy service place, but the only codes I've had pop up were for the vanos solenoid (which has cleared since I cleaned and swapped them), and a couple codes (P1776 and P1777 as I recall) which had something to do with the timing and duration of the fault.
Happens when it's cold or warm.
I did run some seafoam in a tank of gas last week. Seemed to coincide with it getting worse (over a more wide rpm range) but that may just be coincidence.
Had a buddy once tell me that there is a sensor or solenoid on the transmission that could cause a multitude of problems (such as the stalling I was experiencing at the time), but can't seem to cross reference it by searching.
I haven't had any further codes. Maybe due to the limited ability of my OBDII code reader, or, nothing is showing up yet. Figured getting a diagnositc run on it by a BMW shop may be able to pull more codes.
Old 02-09-2013, 02:15 PM
Well, just got back from the garage.
He found no codes, other than for the water pump (don't remember what code specifically). Said all else was within parameters and looked normal. Said that unless I want to throw a lot of money at it chasing down the problem, would be best to wait a little while and see if it gets worse and throws any codes.
Old 02-09-2013, 03:01 PM
laser's Avatar
I'm still wondering about spark plugs (or coils) as plugs were due at 100,000 miles and may have been missed in the turnover from dealer service to after. Do you know when / if they were changed?
Your detailed description of the cars behavior leads my thinking in this direction!
Laser
Old 02-11-2013, 03:37 PM
ebloom ebloom is offline
Mein Auto: M3, 335GT
I've noticed this recently on my 2007 328xit. 109K miles. Its not bad, but noticeable sometimes. Almost like it wants to be in a lower gear. Plugs were replaced around 99K miles, so its probably not that. For now I'm planning to ignore it, not worth a large diagnostic bill that may not solve anything.
Old 02-11-2013, 03:44 PM
johnc_22's Avatar
johnc_22 johnc_22 is offline
Squeal like a BMW
Mein Auto: 2013 Audi A4
I had this exact symptom in my 335i (engine shudder when quicly accelerating in 5th or 6th gear while cruising on the interstate). Carbon build up on intake valves. I don't know if the N52 is as susceptible to this as the N54, but dealer did the walnut blast when fixing some other issues and the problem is resolved.
2013 Audi A4 - Premium+/Sport/MMI/B+O Audio
2007 BMW E90 335i (retired)
Old 02-17-2013, 11:22 PM
Replaced plugs, and the car runs exactly the same (shudder between 1500 and 2100 rpm).
Driving with it over the last week or so on long highway drives, I've noticed this....
-Shudder when transmission in normal mode, and low load increase.
-Also noticeable in sport mode, but less so as the car is not in that rpm range often.
-In Manual mode, and selecting a gear to keep it in that rpm range, the shudder is not there.
Beginning to think torque converter issues? I imagine if it were any kind of an engine issue, the shudder would still be there under the same load conditions while in manual mode.
Also, in reading up on different tranny issues, I wonder if a failing battery could cause this? I haven't thrown a meter on it yet, but believe the battery is going. Slower turnerover during starts, and if accessories are left on for a while (20 minutes), much slower turning over.
I've read how with a failing battery our cars transmissions will sometimes go into "safe mode", but is it possible a low battery could be causing coverter lock up problems or otherwise affecting the transmission creating this shudder?
Old 02-18-2013, 05:24 AM
Replaced my original battery last fall (still seemed OK, but had a slow crank one cold morning, so decided that 6 years and 100K miles was good enough.)
Old 02-19-2013, 11:05 AM
Well, looks like I've got it isolated to the torque converter.
Added 2 x 2oz tubes of the "Dr Tranny shudder fix" yesterday. Took it for a 40 mile drive, and also took a few loops on a several mile stretch where the shudder would show up really bad (moderate incline, moderate speed hill). The shudder looks to be 95% eliminated. I'm not sure I'm feeling it at all now, and a couple times I thought it was coming on, I'd drop into manual mode, and it would remain (road vibrations). On the 55 mile drive to work this morning, nothing. I'm hopeful, at least for now, this has worked.
I also did the "adaptive transmission reset". Should have driven it after I did that, but didn't, and pulled it into the garage the next morning to do the work. Not sure if the "reset" (which I know there is some controversy about if it even works) did anything, or if it was the adding of the shudder fix fluid, but it is shifting / downshifting much more as should be expected.
There was no signs of leaks on the tranny. As I put in the 4 oz, none leaked back out. As far as I know (bought it as a CPO vehicle) the tranny has never been serviced, but wondering if fluid could be low.
I'd like to do a pan drop / filter change / refill, but I'm nervous about that as the car has 135k miles on it now, and am worried about a drain and fill making things worse.
Old 03-23-2013, 07:52 AM
dformica dformica is offline
Mein Auto: 2004 x3
how do you add anything to the transmission without a dipstick
2004 X3 MINE'S
2007 328XI WIFE'S
Old 03-23-2013, 08:36 AM
Husband Husband is offline
Mein Auto: E92 335xi
It could be many, many things, but I'd believe it to be injectors, carbon buildup or coils. I'm dealing with similar mild symptoms right now and have narrowed it to those. My 335i is a manual though, so torque converter isn't a point of failure :-) please keep us posted how this goes!
Btw, if there is no dipstick there should still be a filling bolt and a drain bolt. That's probably how he topped it up.
E92 335xi
Old 03-28-2013, 07:45 PM
Yes, I added through the fill plug on the tranny.
I've put about 3k miles on it since adding the shudder stop, and it has not come back once. Car is running like a dream. Keeping fingers crossed.
Old 03-30-2013, 12:36 AM
Gig103's Avatar
Gig103 Gig103 is offline
Not a Bimmer driver anymo
Mein Auto: 2014 Tesla P85D
I've felt this a few times on my 335xi but with a manual transmission, when in 6th and giving it moderate throttle without downshifting. My injectors were replaced 30k miles ago, my spark plugs only 4k ago. No codes so I'm just letting it go for now or chalking it up to the car struggling being in too tall a gear.
Old 03-31-2013, 08:49 AM
My latest theory based on some other threads is Flywheel. I've ruled out all signs of a misfire. The engine is running fine.
http://www.n54tech.com/forums/showthread.php?t=16218
E92 335xi
Old 08-03-2013, 07:21 PM
Wanted to post an update to this...maybe someone else will give it a shot and benefit.
I've now put 16k miles on since I added the Dr. Tranny Shudder Fix (yeah, I drive A LOT).
There has not been so much as a hint of the problem returning. Definitely worth a try before you go the route of having the torque converter / tranny done.
Old 09-10-2014, 03:48 PM
mitul333 mitul333 is offline
Mein Auto: 2011 328 XDrive/03 325 xi
How is it working? Any update.... BMW released a bulletin early this year.
Old 10-14-2014, 10:10 PM
AsiaBimmer AsiaBimmer is offline
Mein Auto: E90 325i Sport
BMW Bulletin
Hi mitul333, may i know what is this bulletin that BMW released early this year? I have the same problem and have a problem getting the 'Dr. Tranny Shudder Fix' where I live.
Old 10-15-2014, 08:05 PM
Got my transmission replaced under warranty and seems to be fine. I will post it later.
Old 10-16-2014, 02:58 AM
Jimmy Choo Jimmy Choo is offline
Mein Auto: 325
This is interesting. My E90 325 had similar symptoms about a year ago. It feels as if the engine is straining when I try to accelerate on high gear. It feels like a low frequency rumble or shudder.
The Authorised Dealer's tech people just had no idea what the cause was. They could reproduce the shudder when they drove my car. They tried changing the ignition coils to no effect. Then they tried updating and re-installing the software with no joy. They then suggested changing the transmission, which would cost an arm and a leg.
I took the car to another workshop for a second opinion. The technician took one drive in my car, re-produced the symptoms and pronounced confidently that it needed a transmission oil change, even though BMW considers the transmission oil is for life.
I was going for a long trip, so I asked if it was OK to do it after the long trip. The man assured me that it was OK and that nothing would break. So I drove more than 800 km and a few days after, the shudder disappeared! It never came back even after we drove back from this long trip.
The peace lasted for 6 months after the shudder went away. Anyway, by then I was in the process to trade-in the car back to the Authorised Dealer for a new 5-er. So they could have the problem back and "good luck" to them!
After following this thread and seeing how the OP solved the problem with his 'Dr. Tranny Shudder Fix', I think, Mr AsiaBimmer, you may be able to solve your problem with just a simple and inexpensive transmission oil change. Also consider the second opinion I got before the long drive.
AsiaBimmer, do keep us posted, how things pan out for you.
Old 11-06-2014, 10:31 PM
Quick Update... put in a bottle of Lubegard Platinum about 2 weeks ago. The effect kicked in after about 20km and the shudder is now gone like magic! I have driven over 1000km now and the engine and transmission feels tighter and snug. Definitely no more shudder... :-). I'm feeling my fuel consumption has gone up slightly, maybe about 3%-5% maybe because I've been trying out different driving styles to test the result. I've also noticed a strange smell after I have parked in the garage coming from the exhaust.... not sure if that's related.
I'm still trying to figure out how this Lubegard works and how long it will last. Anyone knows?
Old 04-24-2015, 12:24 PM
james2538 james2538 is offline
Mein Auto: 2011 328i
Any word on the Service Bulletin/TSB for this issue? I'm having the same problem and my vehicle is under warranty.
