E90/E91/E92/E93 (2006 - 2013)
Old 02-08-2013, 01:55 PM
MYWIFESBMW MYWIFESBMW is offline
Mein Auto: 2010 328I XDRIVE
wheels and tires
My wife just bought a 2010 328i xdrive. I have worked as a director in a domestic service and parts department. It's a nice car but the 16" wheels make it look bland. I have been doing some homework on putting 19" wheels 313 style 8.0 frt and 9.0 rr...40 offset frt and 35 offset rr....tires i would like to go with 235/35 frt and 275/30 rr...i just want to fill the gap with more wheel and tire...since it's an xdrive, i have read that the diameter needs to be real close....my question is will that combo work on my vehicle without rubbing and do you think it would fill the gap some?
Old 02-08-2013, 02:45 PM
LarkHouston's Avatar
LarkHouston LarkHouston is offline
Doing the best I can
Mein Auto: 2009 335i Coupe
I believe it will, but if I had to do it all over again, I'd go with 18s. I think the 313s come in 18s. The other issue that has been alluded to with putting 313 19s on the 328 is that the brakes are smaller on the 328 and with the 313s having so much open area, the brakes look small. If true, another reason to go with the 18s.
You can find multiple threads discussing the pros and cons of 18 v. 19. Read Nordic Kat's sticky how conducting searches.
2009 335i Coupe/DinanS3/Dinan CAI/Dinan High Capacity Oil Cooler/Dinan Intercooler/BMW PE/M-Aero Front/M3 Rear Spoiler
2006 Z4 3.0si/AA Tune/RPI Intake/OZ Ultraleggera/UUC SSK&DSSR/Cosmos Racing Strut Brace
Old 02-08-2013, 03:09 PM
SilverX3's Avatar
SilverX3 SilverX3 is online now
Mein Auto: BMW X3
19 inch 8" and 9" ideally 34front 37rear offset something like that have a look at realoem.com and check 19" offset
06 130i
07 320i
08 E92 325i
Bicycles: Giant TCR Advanced Zero, Argon 18 Krypton
NEXT CAR : A PORSCHE
Old 02-08-2013, 03:13 PM
tturedraider's Avatar
Freedom isn't free!!
18s will look very good and they will perform better, be more durable/less prone to road hazard and more comfortable.
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -- Geo. Orwell
Keep Right, Except to Pass
Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool."
2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it!
2004 330i ZHP Imola/NB - missed
2000 328i TiAg - gone but not forgotten
BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School!
Old 02-08-2013, 03:49 PM
SD Z4MR's Avatar
SD Z4MR SD Z4MR is offline
(formerly SD 335is)
Originally Posted by LarkHouston View Post
...I'd go with 18s. I think the 313s come in 18s.
18" Style 313 wheels are standard on the 335is. Awesome wheels! The 335is is the first car I've owned that I have no desire to change either the wheels or the exhaust!
- Tom
Old 02-08-2013, 08:16 PM
Chop362's Avatar
Chop362 Chop362 is offline
Mein Auto: 2013 335Is
Hey Tom glad I found ya..Went with better judgement and chose the 18' 313's with plenty of deliberation but other than the bling factor couldn't find another excuse to exercise stupidity i.e Bent/cracked rims coupled with excessive tire wear. Thought about tearing off the run flats but this is all becoming a pain in the butt. How do the wheel wells look??Too much room?? Or just right??
Old 02-09-2013, 04:15 AM
335is Coupe JB4-G5 ISO
Mein Auto: 2011 335is 7DCT Coupe
There is no hard & fast answer on the fit. I have 245/35/19 & 265/30/19 on 313's. I know others who have 275's on the rear.
The problem is there is no standardization among tire sizes. My tires are Conti DW but a set of Yokohama Advan AD08 in the same sizes are a bit over 1/2 wider at the tread. When I had a Acura TL I ran Yoko 100's in a 255 size all the way round. They were a full inch wider at the tread than a Goodyear F1 in the 265 size that someone else was running.
You will just have to take actual measurements against the spec of the specific tire you are interested in to see if it will fit.
Kevin
2013 BMW 135is 6spd conv - 2011 BMW 335is Coupe JB4/ISO
2010 BMW X3 - 2009 Ford Expedition 4X4 EL - 2009 V-Star
2003 Nissan Xterra 4X4 - 1998 Ford Ranger 4X4 Splash
Old 02-09-2013, 06:54 AM
Mein Auto: 2007-335 HTC
not sure what you mean that tires are not a standard size. it shouldnt matter who the manufacturer is but a 245/30/19 should all be identical in measurement from each manufacturer. I am sure there is a tolerance but plus or minus an inch, I doubt that
245 would be the tire tread width in MM
30 is the aspect ratio, tire height in percent of tread width ie 30 percent of 245 mm is 73.5 mm height( but not sure where they take the measurement, from the bead to the tread or what is showing when the tire is mounted
and 19 is the rim size in inches that the tire fits, or the internal diameter of the tire
maybe you are measuring the tires wrong. But 245 millimeters is 245 milimeters no matter what ruler you use or county you are in
Old 02-09-2013, 07:03 AM
Thanks for the info
Old 02-09-2013, 07:47 AM
245mm really actually is 245mm but it depends a what point on the tire tread the factory took the measurement, how rounded the shoulder is vs. a more square cut shoulder. Take a look at tire rack specs Conti DW[B] 265X30X19 tread width 9.5" vs. Yokohama Advan AD08 255X30X19 tread width 9.9"
So here we have a 255X30X19 tire putting almost a 1/2" more rubber down then a 265X30X19 tire. When you are increasing tire size you really need to be very careful about what you are doing. Another very critical dimension is section width which is the widest part of the tire. To wide a tread might rub the fenders & to much section width can hit the suspension components.
BTW if you really have a problem with this I can take the trouble to dig up an old picture of my 255 yokos driving over a ruler showing 10" gone from a 12" ruler. If I am just speculating about something I say that I am so as not to mislead people in the threads I am in. Just like everybody else I can & have made mistakes but generally in a contentious situation where I can I will post a picture. There is a whole thread on 255 tires on the Acurazine 3G Acura TL tires forum where I and another guys posted pics of our 255 tires & my Yokos were wider then his Goodyear's by an inch & equal to a set of 275 Goodyear's.
EDIT Page with the most info
http://tl.acurazine.com/forums/showt...+tires&page=11
Kevin
