Old 03-04-2013, 07:13 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
BMW E90 LCI Rear Indicator Lights
question (my freinds' car)
How do I relace rear LED Indicator light BULB or Panel ? (2009 LCI E90 Model)
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 03-04-2013, 10:42 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
1. Open trunk.
2. Pry/pop out trunk lining access panel behind light cluster.
3. Remove nuts (8mm IIRC).
4. Remove & disconnect cluster.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 03-04-2013, 11:43 PM
SilverX3's Avatar
can he buy replacement LED cluster only ???
Job - Captain
MY11.5 X1 Xdrive25i
Old 03-05-2013, 06:45 AM
Zeichen311's Avatar
I think the LED array is integral to the panel. The incandescent lamps are obviously replaceable but if one or more LEDs have quit, I seem to recall reading you need to replace the whole socket panel.
Old 03-05-2013, 07:53 AM
Banned
Mein Auto: 2007-335 HTC
nope not replaceable, I just went thru the same thing with my 07 335I, the whole unit has to be replaced, once I replaced it I mangled the old unit to see if it is, and its not, I cut it apart with a cut off wheel just to see what it looked like on the inside, its got a circuit panel board inside too, thats probably what died. I have also noticed that the other lamps, only one seems to be replaceable the rest I could not pull them free of the board to use as spares.
Hondo
Old 03-05-2013, 11:44 AM
SilverX3's Avatar
Ok... Dealer quoted $300+ for one rear led panel
Job - Captain
MY11.5 X1 Xdrive25i
Old 03-05-2013, 01:52 PM
Banned
go thru bmw parts of south atlanta, I savde about 60 buck from what the local BMW place wanted, and I just ordered the upper strut mounts and saved about 60 dollars each on them
Hondo
