Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 02-08-2013, 06:30 PM
papabmw papabmw is offline
Mein Auto: 650i Covertible
Vacuum Pump Seal
I am replacing my Vacuum Pump seal and wondered if I should put a little RTV on the head before I reinstall. Is that a good idea or a bad idea?
Thanks,
2007 650i Convertible
Old 02-08-2013, 07:27 PM
HerbP HerbP is offline
It would not hurt, but it is not needed. Make sure you lubricate the seal, before installing it.
Good Luck!
Old 02-08-2013, 07:34 PM
tampamark tampamark is online now
Mein Auto: 2006 650 convertible!!!
Thanks,
From what I have read it makes it easier to keep the new gasket in place. It is a tight fit and wants to "pop" out of the groove.
Old 02-08-2013, 07:39 PM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Living in Fast Forward
Mein Auto: 2007 E63 650i
Thanks,
RTV is some good stuff to help with gasket seals. I'm sure you will be fine using it.
Once a 6'er, always a 6'er.
Old 02-08-2013, 09:57 PM
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
If you look at my pics on my vacuum pump seal change on a previous tread I did just that I put it all around the outside edge and a little on the O ring as TampaMark said it helps keep the ring in place for install.
Just be sure to not get any on the inside if you do clean it out. While you are doing it I would change out the oil sending unit that is right under the pump. Since the pump is out it will so much easier. They seem to start leaking about the same time.
Sent Via iPhone using BimmerApp
Old 02-09-2013, 08:06 AM
Thanks for all the replys! Off to change the pump and oil sending unit today.
