Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 02-08-2013, 06:36 PM
bimer8821 bimer8821 is offline
Mein Auto: 740i
Unhappy help please alarm problem
hi i have a bmw 740i 1997 that keep blowing the alar fuse that is located in the trunk please help :cry
Old 02-09-2013, 05:35 AM
QSilver7's Avatar
QSilver7 QSilver7 is online now
When you lock your car (manually) with the key...walk around to the fuel filler door and see if it is locked or unlocked. If it is unlocked...it is probably the culprit and is blowing the central locking fuse that is in the trunk.
You can unplug the electrical harness to this actuator, then check the fuse to see if it is still intact (not blown). Then take note if the problem persists...or is cured. If cured, then the culprit is the fuel filler door actuator (#12 in diagram below)or the bowden cable (#11 in diagram below).
You can then choose to replace it, or leave it be if an unlocked fuel filler door isn't an issue for you.
The fuel filler door actuator is located behind a black backing plate (#15 in the diagram above)...and tucked into the cross brace for the rear fender (behind the insulation above the battery). In the pic below, you can see the actuator (still attached to the backing plate) removed and turned around...the electrical connector is on the lower left (in the pic)...so when you're looking for your electrical harness as it's still secured in place...it will be on the lower right (again, the image below is flipped around so you can see it):
Q {BMW CCA Member #191509}
(SOLD)
Old 02-09-2013, 06:43 AM
Mein Auto: 740i
Red face thanks
i unplug the thing that you tell me and keep blowing the fuse? ?? waht could be and also unplug the hood sensor and noting thaks again for your help
Old 02-09-2013, 02:31 PM
QSilver7's Avatar
Which fuse is blowing? Fuse 56 or fuse 58?
(SOLD)
Old 02-09-2013, 02:59 PM
Mein Auto: 740i
t
the 56 is fine is the 58
Old 02-09-2013, 03:19 PM
QSilver7's Avatar
Fuse 58 basically is for the fuel filler door actuator. Are you sure you disconnected the electrical harness to the fuel filler door actuator...or did you just pull the manual release cord (I only ask because that has happened several times in the past)?
You can see the manual release cord for the fuel filler door in the image below...it has a black plastic tip connected to a "wire" in the middle of the pic just above the battery:
(SOLD)
Old 02-11-2013, 05:30 AM
Mein Auto: 740i
yes i disconect the actuator and keep doing the same thing
HTML code is Off
