Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series
5 Series
Ask questions and discuss the 5 Series here. If you would like to see all new posts in all the forums, click here.
Old 07-29-2004, 09:51 AM
DotBalm DotBalm is offline
Send a message via Yahoo to DotBalm
Mein Auto: '04 545
E60 - How access rear fuse box
Would like to check a fuse located in the E60 rear fuse box. Owner's manual and fuse diagram in first aid kit only help in locating area in trunk, but no description re how to remove the right trunk liner or whatever is required for access. Prefer not to experiment.
Anyone know how to do this?
________________
2004 545 Black Sapphire Metallic, Black Leather, Anthracite Trim, Sport Pkg, Premium Sound. Window Tint.
Delivered: 6/1/04
Old 07-29-2004, 11:34 AM
WAM's Avatar
WAM WAM is offline
ober-slacker
Send a message via AIM to WAM
Mein Auto: 325i Sport
Last August 2003, during the Monterey Historics, BMW had a pre-production 530i on display at their stand. The trunk liner had a little door that gave access to the fuses on the right side of the trunk. They had a similar door on the left side for the nav and cd changer.
I found a pic I took I took of that car but I can't see the door, although I know I opened it to look at the fuses.
Old 07-29-2004, 11:39 AM
Mein Auto: '04 545
Thanks very much, WAM.
That's what mine looks like and I don't see the door in mine. I did lift the trunk liner mat, but still no love. The left side has a door like you say. Hmmm...I wonder if there is a screw or clip that I'm not seeing.
I'll post what I find out if the solution isn't posted by someone else first.
Thanks again.
________________
Delivered: 6/1/04
Old 07-29-2004, 11:56 AM
mrbelk mrbelk is offline
Send a message via MSN to mrbelk
Mein Auto: 07 335i/6sp
There are a couple of steps to take:
1. on the right-side trunk liner panel, locate the two plastic looking slotted screwheads (they're about the diameter of a dime or a little smaller. Turn them with a screwdriver until they "loosen," and then pry them out.
2. Lift the trunk floor panel and hook it to the body with the little hook.
3. you should now be able to remove the panel with a little effort. It is interleaved at the front to mesh with the liner panel that meets the seatback trunk liner.
Once you get it out, you'll see the battery compartment and fuse box.
-MrB
(ED 5/11/13) '13 328i M-Sport Estoril Blue II/Black, Trip Journal
(ED 5/25/10) '11 335i M-Sport Le Mans Blue/Oyster, Trip Journal
(ED 5/19/08) '08 X3 3.0si Alpine/Tobacco, Trip Journal
(ED 5/7/07) '07 335i/6sp TiAg/Lemon, Trip Journal
(ED 4/18/05) '05 X3 3.0 Blue Water/Black, Trip Journal
(ED 4/28/04) '04 545i Silver Gray/Beige
Old 07-29-2004, 05:29 PM
Mein Auto: '04 545
Problem solved
MrB,
In a word, HUGE.
Problem solved.
Helps to know to look for 2 screws. The one I was too blind to see was the one on the right side. It didn't help that the one I did see, nearest the tail light, turned but didn't seem to unscrew. I unscrewed the side and then pried the one near the tail light after turning it ad nauseum. The rest is history. Confirmed my fuses weren't blown. Photos attached in case someone else is interested.
Many thanks.
ID:	34702   Click image for larger version
ID:	34703   Click image for larger version
________________
Delivered: 6/1/04
Old 07-29-2004, 07:03 PM
You're welcome. I got to be a pro at removing those panels when I installed the CPT9000 eject box and antenna cable connections.
-MrB
