Old 02-10-2013, 02:55 AM
bmw e60 2008 bmw e60 2008 is offline
Mein Auto: bmw e60 2008
bmw e60 2008 transmision oil type
Dear bimmers hello
Please help me i am change in my bmw e60 automatic 2008
Atf oil 9,5 lit .and oil pan whit filter..
After this i see my oil specification is dexron 3 h .
Did a make mistake and what can i do now
i do reesearch and my gearbox i think is not exacly for this oil
please if somebody for sure know did this oil will be problem or which oil exacly is for
6hp automatic bmw e60 .
now my bmw drive very good whitout problems but in my head is nightmare about this now
Thank you in advance
Old 02-10-2013, 06:17 AM
Florida550i Florida550i is offline
Mein Auto: 2008 550i M sport
Requirement for 6 speed auto = Shell M-1375.4
You need Dexron VI ... However:
Dexron-VIThe fluid specification for Dexron-VI was introduced in 2005,and was first used as the GM factory-fill automatic transmission fluid for model year 2006. All Dexron-III licenses expired permanently at the end of 2006, and GM now supports only Dexron-VI fluids for use in their automatic transmissions.[3] Fluids asserted by their manufacturers to meet Dexron-III standards continue to be sold under abbreviated names such as Dex/Merc, but the licensing system no longer exists. These fluids are not regulated by GM.[4] Dexron VI is of a slightly lower viscosity when new compared to the prior Dexron fluids (a maximum of 6.4 cSt at 100C for Dexron VI and 7.5 cSt for Dexron III), but the allowed viscosity loss during use (from shearing of the ATF) is lower for Dexron VI, resulting in the same lowest allowed final viscosity for both Dexron III and VI (5.5 cSt).[5] The intent of the lighter viscosity is to gain an incremental improvement in fuel economy by lessening parasitic drag in the transmission. Since Dexron VI is not allowed to thin out (lower its viscosity) as much as Dexron III during use, it requires the use of higher-quality, more shear-stable (thins less in use) base stocks (the base oils, to which additives are added to make ATF).[4]
Old 02-10-2013, 06:31 AM
Thanks for answer
Yes when i doing my research after changing oil etc i find that i make mistake about oil
Even i am not chose oil service man sell tto me this oil dexron 3 ..
So now i am afraid to damage transmision
I find oil which meet spec. From shell 1357.4
Now i have in plan change again trans oil even i must again spend some money
To mouch people say to me dont need change now
However i cant stop having nightmare about this
Becouse i know what will happend and what will cost me whan transmission is damaged
I learn this on my ex bmw e39
Old 09-18-2013, 06:39 PM
michael64 michael64 is offline
Mein Auto: 2008 z4 3.0i bmw
automatic transmission oil change
has any one used liquid moly top tec 1200 in there automatic transmission / and how is it working I have a z4 2008 and im fixing to do a oil change
Old 09-18-2013, 08:00 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
I would use the original ZF transmission fluid on anything that has a ZF transmission
www.thectsc.com has it for reasonable prices for what it is
Old 09-19-2013, 04:59 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
Does the normal ZF transmission and the Sport Automatic transmission have the same fluid capacity?
