Old 02-10-2013, 10:53 AM
tamir15 tamir15 is offline
Mein Auto: 2006 750i E65
E65 aftermarket backup camera - NEED HELP
i am having issues installing an aftermarket camera on my E65.
i am connecting it to a monitor on the dash (not the nav screen).
my problem is with the 12v power to the camera. when i connect it to the reverse light bulb wire the image flickers and no steady image.
when i connect it to a regular 12v in the trunk (trunk light bulb or any other 12v) i get steady image and no issue.
does anybody know what may be the problem?
Old 02-10-2013, 11:17 AM
First_745Li's Avatar
First_745Li First_745Li is offline
Mein Auto: 2007 Audi A8
Can you post up some pictures of the wiring at the backend, meaning the wires you're trying to connect..
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Old 02-10-2013, 11:22 AM
Check this thread out..
http://www.bimmerfest.com/forums/sho...reverse+camera
Also see the attachment should include wiring diagram
File Type: pdf BMW Rear-View Camera Retrofit for E65 and E66.pdf (507.0 KB, 770 views)
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 02-10-2013, 12:04 PM
hey,
thanks for the quick reply.
sorry but i have everything put back together now so i cant take pictures.
i connected both to the connector that feeds the reverse light bulb and to the light bulb housing it self (same result). i verified the wiring so i know this is not my issue.
for some reason there is a distortion but i am not sure why or what it is.
the forum and pdf you attached is for a kit that includes control boxes and other items that go with it. it doesn't tie directly to the reverse light bulb wires.
i can run the camera power line to the front of the car (just like i ran the video wire) but where would i connect it to if i ran it to the front?
Old 02-10-2013, 01:08 PM
rippjd rippjd is offline
Mein Auto: '05 745i / '10 X5 35d
It's possible the light module sends a pulsed (PWM) voltage to the reverse light. Your reverse camera kit likely needs a steady voltage.
2005 745i Individual
E65/E66 Parts for Sale:
Alpina Type 743 Front Spoiler complete retrofit kit (new in box) $1200
Old 02-10-2013, 01:15 PM
Nygel's Avatar
Nygel Nygel is offline
Mein Auto: BMW 750Li
you will need a relay for the 12volt activation
Old 02-10-2013, 01:37 PM
ok thanks Nygel and rippjd. i figured the car electronic module sends the voltage to the reverse light bulb and doesn't like another load or doesn't send steady 12v.
i need further help please: what kind of relay? where do i buy it?
once i get it where do i connect it? between the cable connector and the light bulb?
Old 02-12-2013, 06:17 AM
bk750 bk750 is offline
Mein Auto: 2007 750 li
was up go online and forget that monitor hook it to your nav screen its call navtool I have it installed u can also watch movies on it
Old 02-12-2013, 12:57 PM
ok finally got it to work. i bought an automotive relay at Radio shack and used it to switch the 12v from the reverse light bulb 12v to a steady 12v.
works like a charm.
cost me $40 for the camera and rear view mirror monitor and two days of work but it is definitely worth it.
thanks for the help
Old 02-27-2013, 12:56 AM
as3070971 as3070971 is offline
Mein Auto: 2002 bmw 745
Can u send of pic of camera installed on vehicle. Have the navtool connected already. Wasnt sure what kind of camera to use or how to Install. Thanks.
Sent from my SGH-T999 using Bimmer App
Old 02-28-2013, 09:13 AM
i will try to take some pictures and post them. this is much easier than connecting it to the nav screen. you will need to buy a rear view mirror monitor and route the video cable from the camera (mounted on the license plate) all the way to the rear view mirror
