E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
OK guys, give me a hand. Will the 5 spoke, 4 bolt Mini Cooper wheels fit on my E30 and moreover will they be the right diameter and look good or? What wheels can you recommend? thanks all!
Dunno. Measure them.
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
Mini's are 4 x 100 same as the 4-lug E30, but offset varies. Also, the center hole may not match (too big/small)
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
our centerbore is 57.1, think minis are 66, so you'll want centering rings.
as far as width, you'll want fronts as 7" et25 or 8" et 13, rears can go as wide as 9" et 0 |
Mini cooper rims have a hub bore of 56.1mm and will have to be modified to fit the E30's 57.1mm hub. Also the mini cooper rims have high offsets (40mm), so you will also need four15-20mm hub centric spacers with longer lug bolts.
Big Boyz with Bad Toyz. Last edited by BigBoy740il; 03-02-2013 at 10:05 PM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
