E36 (1991 - 1999)
Old 02-10-2013, 07:05 PM
bb94325i bb94325i is offline
Mein Auto: 94 325i Convertible
Question Brake Light Confusion
Got the brake light switch fail message on my 94 E36 325ci. Changed out the brake light switch and the bulb. Now getting brake light failure still. Why? Could I have blown fuse or
other brake light electrical issue? Thanks.
Old 02-10-2013, 07:11 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
So to clarify, are you getting the bulb out warning, or the brake circuit failure?
1998 BMW 328is
1966 Pontiac GTO
Old 02-11-2013, 06:40 AM
Brake Light Failure
It is now the failure notification. My bulb seems to be actually going out on the drivers side as well. I changed it and it seems to still not be working at all times.
Old 02-11-2013, 06:52 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
Check the fuse. Then clean the contact points with the bulb from the housing. It's probably corrosion.
Old 02-19-2013, 07:53 PM
Smile Contact Points from the Housing
I gently cleaned the contact points by sanding a bit and wiping. Seems the brake light is functioning again. Thanks for this pointer!!! Much appreciated. Can't wait for some Spring Weather and to put the top down!!!!
brake light circuit, brake lights, brake lights failure
