The X5 SAV Forum
Old 02-10-2013, 08:48 PM
juggler1972 juggler1972 is offline
Mein Auto: x5
about to fail Inspection for rear wiper
might sound silly but I cant seem to get my rear wiper on my wifes x5 3.0 to make / stay in contact with the rear glass . Therefore its not cleaning the windshield . I thought no big deal until my mechanic fails me for inspection ( in PA you have to get a mechanic to pass you for inspection .) ANyone have any thought here -- I tried adjusting the arm cleaned the spiral shaft and with a small brush but I still cant get it to stay in contact with the windshield .
Name:	rear windshield.jpg
Old 02-10-2013, 09:30 PM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
Look for another Mechanic that willing to "Work" with you.
Old 02-10-2013, 09:46 PM
dryflyguy dryflyguy is offline
Mein Auto: 2006 X5 4.8iS
New blade maybe?
Old 02-10-2013, 11:34 PM
Mein Auto: x5
tried new blade -- nothing ? Wondering if the wiper arm might be bad . Cant see how a wiper arm would malfunction but who knows . Clearly the old and new blade arent contacting the window-- ive tried bending it but doesnt seem to work!
Old 02-11-2013, 07:50 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Loss of spring tension over time. New wiper arm should take care if it. Find a cap for the nut at the base end of the arm to prevent rust.
Old 02-11-2013, 08:03 AM
Mein Auto: x5
thanks boramkiv -- just wanted to make sure that was the problem before ordering the part. I appreciate the help
Old 02-21-2013, 08:52 AM
Crash1976 Crash1976 is offline
Mein Auto: 01 X5
just lubricate the hinge on the wiper blade if it gets a little rusty some wd-40 will work wonders.
Old 02-21-2013, 10:03 AM
TechWrench TechWrench is offline
Mein Auto: '99 540i, '02 X5 3.0i
Ditto that. I had same problem with our '02. Hinge was rusted, and wouldn't hold blade against glass. Used WD-40 and flexed hinge joint until it moved freely. That was over a year ago, and it still works as designed.
Old 02-22-2013, 07:40 PM
DirtyDan's Avatar
DirtyDan DirtyDan is offline
Mein Auto: 2003 X5 3.0i
Spray white lithium greese underneath on the spring. I had the same issue and usually happens every other year. Lithium greese cures the problem. And find a cap for the bolt so not to cause damage to the arm. Another trick is take a plastic bag sleeve like what a newspaper is delivered in and slide over the arm to keep the rain off the spring.
