Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 02-11-2013, 06:27 AM
dario pinet dario pinet is offline
dario pinet
Mein Auto: bmw 750il 1998
navigation
my navigation is not going to sleep,the light still on, and in couple days my battery is dead,
look like i need new navigation ,does any member has this problem before?
Old 02-11-2013, 07:29 AM
speedkingrc speedkingrc is offline
Mein Auto: 88 BMW 735i
i got a nav you can get from me.. im going to swap my factory one out with aftermarket anyway. so u can get the drive and cpu for 200... **** i will even thro in the disc changer for 25 more
i have a 97 bmw 740il i think they use same in ur yr n mine. far as i know
Old 02-11-2013, 02:44 PM
dario pinet
look ok , but i need make sure if my navigation is the problem, i no want to buy urs if i have same problem, look like need check the circuit and module in my car before do it , thanks i let you know.
Old 02-11-2013, 07:52 PM
ok u welcome. thought i would help as much as i can
Old 02-11-2013, 08:55 PM
BMWFatherFigure's Avatar
Old School
OP - You said the Nav is not shutting down and then you are not sure if the Nav is the problem. OK - what else doesn't shut off?
Current:
Previous:
Old 02-12-2013, 06:19 AM
dario pinet
just the navigation lights
Old 02-12-2013, 01:44 PM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
Has the nav been removed recently, and if so is it the Mk3?
Old 02-12-2013, 02:25 PM
dario pinet
it is mk2 , yes i removed couple time and i put back, just work ,but like i said all the lights still on
Old 02-13-2013, 12:25 AM
Old School
I am starting to think: Plug part out; earth not remade; bent pin in one of the plugs. Funny how the 'I had it out a couple of times' part got glossed over....
Current:
Previous:
Old 02-13-2013, 07:03 AM
dario pinet
thanks i willl.
Old 02-20-2013, 08:05 PM
dario pinet
I bent the pins,nothing change also there couple speakers make a lot noise (static) ,so i disconect this speakers and the navigation,still have stereo and also loose 0.3 volt each 12 hours,i mean every night
HTML code is Off
